95 dc2 throwing codes...
ok i did the jumer harness thing and my ecu is throwing code 10 and code 6, which are for the iat (inake air temperature sensor) and the ect (engine coolant temperature sensor) what else, if anything, would cause the ecu to throw these codes other than the sensors being bad cause my ect seems to work fine, the fans turn on and the gauge works just fine. plus the cel doesn't come on while i'm driving, only when the key is turned and left in the accessory position. someone with some knowledge please help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frontwheelfanatic »</TD></TR><TR><TD CLASS="quote">wiring's ok, when i had some vtec solenoid issues the cel worked great and reset codes just fine</TD></TR></TABLE>
So you took a multi-meter and probed the circuits according to the helms ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frontwheelfanatic »</TD></TR><TR><TD CLASS="quote">for the resistance on the sensors(testing) or the actual wiring?</TD></TR></TABLE>
You have to follow the procedures in the manual.
i'm gonna test the sensors wednesday after work with the multimeter to make sure the resistance of the sensors is within the range its supposed to be for hot and cold, but is there anything ele tha would cause those codes to be thrown?
