'94 LS flywheel alignment
Old Oct 2, 2008 | 08:27 AM
Stephen Wilson's Avatar
Default '94 LS flywheel alignment
When I pulled the flywheel, there was no alignment dowel as the manual stated. I didn't mark the orientation to the crank. Is this a zero balance flwheel, so the orientation won't matter? I tried searching here and google, no definitive answers.
Thanks,
Steve
Old Oct 2, 2008 | 08:41 AM
Kendall's Avatar
Unless there is something horribly wrong, it should be a zero balance flywheel and the orientation should not matter.
Old Oct 2, 2008 | 09:00 AM
KaBlookie's Avatar
Default Re: '94 LS flywheel alignment (Stephen Wilson)
I've never even heard of having to align a flywheel on our engines...and when mine was done we didn't have to do anything special when mounting it, just mount it and torque the bolts in the right order
Old Oct 2, 2008 | 09:09 AM
Default Re: '94 LS flywheel alignment (KaBlookie)
I'm glad to hear that, I want to finish this weekend. There is a hole in the crankshaft flange for a dowel, but not in the flywheel.
Thanks!
Old Oct 2, 2008 | 09:23 AM
SuzukaBlueAP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stephen Wilson &raquo;</TD></TR><TR><TD CLASS="quote">I'm glad to hear that, I want to finish this weekend. There is a hole in the crankshaft flange for a dowel, but not in the flywheel.
Thanks!</TD></TR></TABLE>
I don't where else you would think another hole should be in the flywheel other that right in the center of it. lol
After you bolt the flywheel onto the crankshaft you will use a clutch alignment tool to center the clutch and pressure plate.
Old Oct 2, 2008 | 09:29 AM
Default Re: '94 LS flywheel alignment (SuzukaBlueAP2)
Not that hole! There's a hole between two of the threaded bolt holes, I know about the clutch alignment tool the goes into the pilot bearing. I have the "factory" manual that said look for an alignment pin.
Old Oct 2, 2008 | 09:53 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuzukaBlueAP2 &raquo;</TD></TR><TR><TD CLASS="quote">
I don't where else you would think another hole should be in the flywheel other that right in the center of it. lol</TD></TR></TABLE>
Quoted for not making any sense.
Old Oct 2, 2008 | 09:58 AM
haha gotcha. Didn't quite catch what you were trying to describe at first.
thanks, AWD
xduB95preludeSi
Sep 9, 2016 06:37 AM
ITR-2001
Aug 16, 2006 02:02 PM
mrx
Oct 1, 2004 11:17 AM
pentaq
Apr 29, 2003 04:36 AM
Kataku2K3
Oct 11, 2002 09:49 AM
