94 LS Dead Engine Issue
Old May 3, 2009 | 05:09 PM
terrybogard21's Avatar
Icon6 94 LS Dead Engine Issue
Engine type: B18B USD
Car Type: 1994 Acura Integra LS Hatch
Issue: Possible RIP Engine / Rod Bearing Broke
First off, thanks for looking at the thread, any input is very much welcomed.
The car has always had smoke issues, GF wasn't much concerned with fixing the problem. Shop advised her dad that it seemed like a Piston issue at the time (months ago). Well about a couple weeks ago I go to shift in 1st from a dead stop and press the gas & the car revs to like 7K, but it wouldn't stop revving.
So I pulled over; turned the car off & let it sit for a few minutes. I was able to make it home(less than 2 mins. away) where I parked the car. Next day I go to start it to see whats up and hear this knocking noise...
I knew than, whatever happened didn't seem good & a friend suggested a piston issue. Well here I am couple weeks later with the motor out & seeing all kinds of hell done to this car.
Below are pictures of the damage it seems, I'm wondering if I can even salvage what has been done in terms of damage. Btw, this was my first honda engine pull/engine breakdown & my goodness it seems easy minus the harness.
As you can see:
Pic#1: Shows the bearing along with the piston/connecting rod it was attached to.
Pic(s)#2-5: Show the damage to the crankshaft; I'm wondering if the rod basically killed the crankshaft. You can clearly see that it looks no where near like the others.
I'm just wondering what exactly my options are if any?
1) Junk the engine; sell what parts I can
2) Replace the rod bearing/pistons & rebuild it
3) Buy a whole new engine & move on.
Once again, thanks for the advice & input everyone
Old May 4, 2009 | 03:14 AM
Default Re: 94 LS Dead Engine Issue
bump for morning peeps
Old May 4, 2009 | 04:01 AM
MumBleZ_94gsR's Avatar
just but a b18c online for $1599
Old May 4, 2009 | 04:07 AM
weavertime1's Avatar
...or a JDM B18B shipped to your door for $500 - $1,000. Even a B20 would be a reasonable idea. What issues did you have with the harness? Good luck!
Old May 4, 2009 | 07:04 AM
s2kmugenpower's Avatar
New motor!! rebuilding takes alot of time plus taking the head to get it cut down will be costly i saw get another b18 and be happy that crank looks really badd too from the pics so mine as well sell it for parts and get a new motor
Old May 5, 2009 | 01:06 AM
Well thanks for the input guys, I figured it might be done when I pulled the Crank out. Now I guess the hard part is waiting on HMO.com to get B18 motors back in stock.
Old May 5, 2009 | 06:28 PM
check local spots might be quicker itll save u alot of hassle in the long run make sure when u get the new motor to replace oil pump,water pump, belt tensioners,belt,and oil change of course
foxfai
Nov 2, 2013 03:47 PM
LaCuRa
Feb 19, 2008 07:24 PM
SINFULLSPEED
16
Oct 6, 2004 12:26 AM
92HB_HB
Feb 2, 2004 04:50 PM
