94 integ giving some problems
Old Mar 19, 2005 | 02:58 AM
b18a2705's Avatar
Default 94 integ giving some problems
my 94 integ is is not acting right......when i am in gear and the car is started it jumps, like the clutch wants to engage and disengage when i have the clutch pushed all the way in. when the car is started it will not come out of gear until i shut it off, then i can pull it out but it will not go back into gear once turned off. i can start it in neutral and its fine until i put it into first.
so with that said i believe it's a clutch issue but not for sure. my tranny was grinding in 3rd and 4th gear all the time but never had any problems with first/second gear. any assistance will help..........
Old Mar 19, 2005 | 10:09 AM
b18a2705's Avatar
Default Re: 94 integ giving some problems (b18a2705)
any ideas.......
Old Mar 19, 2005 | 06:35 PM
b18a2705's Avatar
any help
Old Mar 19, 2005 | 09:55 PM
SuzukaBlueAP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18a2705 &raquo;</TD></TR><TR><TD CLASS="quote">any help</TD></TR></TABLE>
Could be as simple as a bad slave cylinder, but it sounds more like a broken spring or clutch disc.
Old Mar 20, 2005 | 09:12 PM
b18a2705's Avatar
Default Re: 94 integ giving some problems (ScreaminTeg)
i am replacing tranny, clutch,flywheel.....hope it works
Old Mar 21, 2005 | 02:50 AM
JBBNJ609's Avatar
yea i had the same problem with my clutch pressure plate, it was doing this, just change out the clutch setup( clutch disk, clutch pressure plate, throwout bearing, pilot bearing) dont drive it liek this if you dont have to, its bad for your tranny ( grinding and it just kickign into gear)
hope everythign works out fro you, and make sure to break in the clutch
Old Mar 21, 2005 | 03:21 PM
b18a2705's Avatar
Default Re: 94 integ giving some problems (jason bouchard)
thanks for the help.....
Old Mar 21, 2005 | 10:23 PM
b18a2705's Avatar
bump
jdmej2lolo
Oct 17, 2008 09:13 AM
Dav94Lx
Feb 2, 2008 07:53 AM
94civicoupe
18
Oct 9, 2006 02:17 PM
loudsubz
May 9, 2004 03:12 PM
Brandon
Jul 31, 2002 09:59 PM
