94 civic, goes into gear but wont move
Old 10-08-2006, 07:45 AM
94civicoupe's Avatar
Default 94 civic, goes into gear but wont move
I just bought a 94 civic yeaterday, drove it up onto the trailer and brought it home. when I got home, it wouldent move. I put it into first gear and let out the clutch, and I can hear things moving around but the wheels arent turning. it also does it in NEUTRAL, I can hear stuff moving around w/ the car in neutral. the only time that things are completely disengaged is with the clutch in. I havent had time to look into it yet, I ddint know if anyone has had a similar problem? I'm hoping it is something simple and not transmission/axle trouble. any help would be greatly appreciated..
Thank you,
Mitch
Old 10-08-2006, 08:06 AM
stock_honda_coupe's Avatar
Default Re: 94 civic, goes into gear but wont move (94civicoupe)
What kind of "things" do you hear moving around?
Old 10-08-2006, 08:27 AM
Slamaccord's Avatar
Default Re: 94 civic, goes into gear but wont move (stock_honda_coupe)
sounds like a clutch to me
Old 10-08-2006, 08:31 AM
Syndacate's Avatar
Default Re: 94 civic, goes into gear but wont move (Slamaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slamaccord &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a clutch to me </TD></TR></TABLE>
If that's a burnt clutch he must realllllly roasted it.
at OP:
Either way you're dropping your tranny and cracking it open, so drop it and have a peak inside.
Old 10-08-2006, 08:32 AM
JDM_Frijoles's Avatar
Throw out bearing is going bad, or needs to be replaced. you sure the trans has oil? check your axles also.
Old 10-08-2006, 08:33 AM
Default Re: 94 civic, goes into gear but wont move (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
at OP:
Either way you're dropping your tranny and cracking it open, so drop it and have a peak inside.</TD></TR></TABLE>or that
Old 10-08-2006, 11:14 AM
well, it cant be the clutch because the clutch felt pretty good when I loaded it up, and I didnt even ride the clutch when I loaded it. the part that gets me is that even when it's in neutral, if the clutch isnt pushed to the floor I can hear things engaging. It sounds like the noises are coming from the front of the car, i'm going to get it up onto some stands here soon and see if I can see the axle spinning and such. If it was the tthrow-out bearing, wouldent I not be able to disengage the clutch? I just dont understan what could have gone wrong from point a to b when it was on a trailer. thanks for your help guys
Mitch
Old 10-08-2006, 11:48 AM
Amped's Avatar
If i had to guess i'd say the clutch is done. Try starting it in gear, does it move? Or push start it that will help you diagnose the trans problem.
Old 10-08-2006, 11:52 AM
Syndacate's Avatar
I say it once again, DROP THE TRANNY.
You're going to need to for any problem that would cause something like this to happen. Might as well just drop it and peak inside, you'll see what's wrong with it surprisingly quickly and that'll be that.
Old 10-08-2006, 11:53 AM
Amped's Avatar
Default Re: (Syndacate)
yup, case closed.
Old 10-08-2006, 11:57 AM
Default Re: (Amped)
Nope, Not case closed.
Left front axle is broken at the CV joint on the tranny. I think the CV joint busted off but I cant really tell for lack of room.
Thanx for the help though guys.
93hatch's Avatar
i agree just drop the tranny and go from there...
if ur good it'll take you less than an hour..
good luck
Old 10-08-2006, 11:58 AM
93hatch's Avatar
it takes five min. to pull the axle so pull it and let us know man!!
Old 10-09-2006, 01:36 PM
g
Old 10-09-2006, 01:39 PM
Former Moderator
B18C5-EH2's Avatar
Default Re: (94civicoupe)
Mother of God I was going to say broken axle after my first read.
Why would anyone drop a tranny without first checking axles?
Are you guys serious???
The noise you're hearing is the axle/inner joint spinning while the outer joint is not - you're hearing axle grinding against itself wherever the break is.
Would you like an axle replacement how-to? This is one I wrote up a while back:
Ever hear a clicking noise when you turn?
Ever feel a vibration only when you're acclerating?
Chances are that you need a new axle. The first thing you'd need to do before you go pulling an axle out of your car is figure out which axle is bad if both aren't. Symtoms of a bad axel would be:
1. Torn boot with grease slinging out. ( :hammerDUH:hammer )
2. One side or the other vibrating upon hitting the gas. This indicates a broken or worn inner joint.
So after you figure out which one (or both) needs replacing you can begin.
I've taken some pics of various tools that you will need in order to swap an axle. I work at a shop so air was available to me, but for you at home there might not be some tools pictured here that you will need - I'll get to that in a minute.
32mm socket
19mm socket
17mm socket
17mm wrench or additional socket
1/2'' driver for big sockets
3/8'' driver for drain plug/sockets
hammer
dykes
prybar
*big-*** breaker/cheater bar for the 1/2'' driver to break the axle nut loose and tighten it back down*
*Optional*
Depending on tranny you might have to drain and fill the tranny. I make this a common practice every time I swap an axle and I recommend that you do too. In my tutorial I will detail how to drain and fill the tranny. If doing so add these things:
3 qts of Genuine Honda MTF (you won't use all 3 - B-Series takes like 2.5 qts.)
Long funnel
crush washer for drian plug (get it from Honda - same one as your engine oil drain plug)
10mm socket with LONG extention
driver for 10mm socket/extension
Here we see the various tools laid out. Missing from the pic is the big-*** breaker car for you at home that will need it for the 32mm axle nut. Also missing are the funnel and 10mm socket.extention/driver combo for the drain/fill procedure. I has air tools available so I used them.
Close-up of cotter pin (you'll only need one) and drain plug washer
Drivers and 17mm end wrench:
32mm, 19mm, and 17mm sockets:
And if you're lucky and have tools a 1/2'' impact will be very helpful:
Okay so let's get started.
1. Take the 19mm socket and break your wheel lugs loose. they will be hard as hell to break loose if you've already got the car in the air.
*For those without an impact*
It has been brought to my attention that if you are using a 32mm socket with a 1/2'' driver and a big-*** breaker bat you might want to break the 32mm axle end nut loose while the car is still on the ground. Hopefully you can access the nut with the wheel still on, because if not you'll have to get someone to sit in the car and hold the brakes on with the engine on in hopes that the wheel won't turn while you try to break the 32mm nut loose.
2. Jack up the car and secure it on a STABLE set of jackstands. I used a lift so sorry, no pics.
3. Locate the drain plug and use a 3/8'' driver with no socket and remive the drain plug:
Replace the drain plug washer and tighten the drain plug back after draining is complete. I didn't do this until later on because I waited to drain the tranny until right before prying out the axle, but I recommend doing this first at home and then tightening the plug back until you feel/hear the washer crush. This insures no leakage during work and also so that you remember to drain and tighthen the plug up before you start the real work.
4. Remove the wheel and look for the 32mm axle end nut. Yeah the pic sucks.
5. Remove the axle nut with the 32mm socket. At home you will need a breaker bar or cheater bar to get much-needed leverage to break this bastatrd loose. I used an impact.
6. Now find the cotter pin lovated on the 17mm castle nut below the lower balljoint and remove it by unfolding it with your dykes:
7. Now take the 17mm socket and remove the 17mm castle nut from the lower balljoint. Yes this pic sucks too.
8. Now take your hammer and beat on the lower control arm where the hammer head is in this pic. This will break the balljoint loose. The pics get better sometime.
9. Now locate the through bolt that holds the lower strut "fork" to the lower control arm:
10. Using a 17mm socket on one side and either a 17mm wrench or another socket to hold the other side, remove the through bolt .
11. Now take your hammer and LIGHTLY tap on the end of the axle to get it free from the spindle:
12. Now pull the lower strut fork to the side and it should all look like this:
13. Now you're ready to pry the axle out. Take the prybar and position like so in the pic and pry. You might want to secure the spindle out of the way so it doesn't hold the axle in:
14. Compare your new axle to the one you pulled out and make sure the new axle is correct. The old axle might not "look" bad, but in this case here the shaft is actually broken in half inside the outer boot.
15. Now you're ready to put the new one in. Simply reverse the removal procedure. First get the spindle out of the way and pop the axle back into the inner joint. It might take a bit of pushing, but it will pop in. Make SURE that the inner joint is all the way in and butted up against the tranny casing fully.
16. Here's where steps can be swapped around, but I did mine in this order. Put the lower balljoint back into the lower control arm and slide the outer splines back into the spindle - finger tighten the 32mm axle nut on so the axle doesn't pop back out while you do other work.
17. Now you're ready to line up the lower strut fork with the lower control arm to put the through bolt in. It helps to tighten the lower balljoint 17mm castlenut first. Replace the cotter pin too! VERY IMPORTANT!!! Remember to tighten the 17mm castlenut in a manner so that you can slide the new cotter pin in.
18. Push up on the lower control arm and slide the through bolt in plave and put the 17mm nut on the end:
19. Using two 17mm sockets or whatever combo you choose, tighten the through bolt:
20. Now tighten the 32mm axle end nut. If you have no air tools then use the breaker bar and tighten it up pretty snug. STAKE THE NUT DOWN! Use the hammer and something flat to make an indention in the nut like pictured:
So the new axle is in. Time to fill the tranny. There's a few schools of thought on how to fill the tranny, but this methid here is by far the least messy and to me the easiest.
*Optional* Find the fill plug. It is seen here right next to the inner joint of the axle. It has a crush washer so if you loose it your'e screwed. Honda doesn't usually sotck this one. I chose not to loosen my fill plug because I know my tranny takse 2.5 qts., but the way you fill it is to fill until fluid dribbles from the fill hole so this is optional if it makes you feel better.
Here's where the trick comes in that will save you headahces. Usually you have to ghetto-rig a funnel and tube to fill the tranny in the fill hole which really sucks. My method is really easy.
1. Remove the vent cap found near the front/top of your tranny:
2. Find the Speed sensor located on the topside of the very back of your tranny:
3. Take the 10mm on a big-*** extension and remove the bolt (it's the orangish one in my pic - yours probably won't be oragnish):
4. Now see that big-*** hole left after you move the speed sensor out of the way? Use the funnel and fill through that hole! By the way, no need to unplug the speed sensor - just move it out of the way.
5. Fill up with specified amount or until fluid dribbles from the fill hole below.
6. Put the speed sensor back in, tighten up the fill plug (if you loosened it).
7. Replace the vent cap and you're done!
Now put your wheel back on, torque the lugs to spec with a torque wrench and take your car for a test drive!
Okay, so I jacked up the car to take a look at the axle today. when the car was on the ground, i could wiggle it all around with my hand. I jacked up the car, and suddenly the shaft wouldent move at all. I let the car down, put it in gear, and now it magically drives. i'm so confused! so I pulled off the boot that is right by the tranny on the axle and there is all kinds of what looks like green grease in there. Is that supposed to be there? I'm not really a tranny guy. so I drove it up and down my driveway just once, and when I got back, there was smoke coming from that area, where the axle goes into the tranny. I dont even know where to start..... can anyone help?
Thanks
Mitch
Old 10-09-2006, 01:50 PM
Former Moderator
B18C5-EH2's Avatar
Sounds like a broken inner joint. I've broken enough of them to know the symptoms, but this is an over the internet diagnosis so anything's possible.
The green grease is nasty-*** axle grease, and it's normal for it to look like that. Looks like baby **** after they've been stuffing green pea Gerber baby food.
I think you've probably got an inner joint that has a busted bearing cage, and it was popped out completely at first when you could not move the car, and by luck it popped back into place and is now drivable.
The smoke? Could be from the grease heating up if some slung out, or it could be from heat if the bearings are seizing up.
With the axle tutorial above swapping it out should be easy. Go to O-Reilly's/AutoZone/Advance and get a lifetime warranty reman axle and since you'll know how to swap it yourself it can be done for free from now on if you happen to tear boots down the road.
Old 10-09-2006, 02:11 PM
92ehatch's Avatar
Default Re: 94 civic, goes into gear but wont move (B18C5-EH2)
the best/most imformative reply ever was just posted above. not only did he say what it was, but a full write up with pics for the OP
hope for HT?
Old 10-09-2006, 02:17 PM
HT White Ops
Eran's Avatar
Great post up thur.
Another decent way to fill a transmission is get a 2 litre bottle and fill it with the appropriate ammount of fluid, and a coffee syrup pump (the best way to get these is to flirt with chicks at starbucks and tell them they have a great personality and you'll get Fall Out Boy to come to their birthday party). Then get some clear hose and pump the fluid into your tranny. It's ****** fun
Talunus
26
06-03-2016 01:41 PM
Sweetz
07-20-2007 03:49 PM
b18a2705
03-21-2005 10:23 PM
takendaily
01-18-2005 05:56 PM
Quick Reply: 94 civic, goes into gear but wont move
