92 gsr electrical problem
Old Jul 9, 2009 | 07:24 PM
ahhshietitztony's Avatar
Default 92 gsr electrical problem
for some reason the battery for my car ( 92 integra gsr ) keep dying on me. if i don't start the car for one day, there won't be enough battery to start the car the next day. i don't think the battery is bad, because it seem to be 100% charged when ever i jump the battery. then battery seem to be completely drain if left for more than a day without starting the car, but if i keep starting the car, its ok.
so i'm thinking some electrical component is shorting the battery. i thought it might be my alarm, because i installed it myself, but i tested it by removing my Alarm's main fuse (+12v), fully charge the battery, but battery is still drain if left for over a day. so it can't be my alarm, can it?
What i think it could be is the FAN (the **** adjusting 1-4) for the Heater/AC for the interior. reason for thinking that is because, i can turn ON the FAN ( turn **** to 1,2,3 or 4) even if my key is OUT OF THE IGNITION...
i just wanted to make sure its not the alarm, and so if it is the fan shorting the battery, does anyone know how should i go on about fixing this problem? is there a simple way to fix this or i have to pull out the dashboard?
p.s. the car was bought like this... have no idea who wired the car
Old Jul 10, 2009 | 03:40 AM
mr.beeks's Avatar
Default Re: 92 gsr electrical problem
I have a 92 with the same problem.
so I figured it out
make sure AC is off before shutting down car and thats it but never fixed it.
alway carry a booster pack cause I forget sometimes.
Old Jul 10, 2009 | 07:53 AM
em1si's Avatar
curious for answer?
Old Jul 10, 2009 | 08:14 AM
stocker2shocker91's Avatar
I requested a short story for a title.
maybe somethin in the ignition switch?? you should not be allowed to opereated the heater controls with the key off.
maybe its not disengauging like it should, ive heard there junk but have never had a problem with mine.
gl
Old Jul 10, 2009 | 05:14 PM
i'll check my ignition switch..
but i'm still waiting to see if anyone out there know exactly what is wrong and how to fix the problem, but mean while i'll check the ignition.
thanks in advance
Wilymakeit
Audio / Security / Video
Mar 11, 2008 10:23 PM
bpr0422
Jan 4, 2008 01:07 AM
teggy182
Aug 10, 2006 04:29 PM
acuraLSSE95
Jun 3, 2002 02:29 PM
