92 DA brake problem
Old Sep 10, 2011 | 11:48 AM
Jayrail's Avatar
Default 92 DA brake problem
I was sitting at a stop light last night and while sitting there my brake pedal pops and goes to the floor. My brakes work probably at about 15% its only enough to slow me down if i'm going under 25mph. Not sure what it is i assume its a brake line because i checked to see if there was brake fluid and theres barely any at all in it now.
second opinions?
Old Sep 10, 2011 | 11:54 AM
98bucket's Avatar
Default Re: 92 DA brake problem
have you checked your brake lines?
Old Sep 10, 2011 | 11:59 AM
Jayrail's Avatar
i havent had a chance to check them because i have no garage and its been raining but thats the only thing i could think of it being seeing as i could hear and feel the pop and my girl said she could feel it too
Old Sep 10, 2011 | 02:35 PM
ludocivic's Avatar
Its definately a rusted brake line or rotted rubber line.
Old Sep 10, 2011 | 10:57 PM
Hidenplanvew's Avatar
Possibke master cylinder rings failed.. See if brake fuid is leaking by where the pedal is
Old Sep 11, 2011 | 10:05 AM
98bucket's Avatar
is the paint from your vacum booster(that thing were your master cylinder is attcahed to) peeling off? if it is then you have a leak, which means your the rings on your primary piston have failed.
hteg12
Jul 18, 2013 05:13 PM
98integralsB18
Suspension & Brakes
Mar 8, 2012 10:17 AM
USDM-EK4*
Apr 4, 2008 07:50 PM
limpy
Mar 4, 2006 07:13 PM
KarbinFourteen
Oct 16, 2004 06:45 PM
