91 integra obd 0 to 1 conversion
i have a 91 integra ls hatchback with a non vtech b18b1 that im getting sleeved and boosting with 550cc fuel injectors and i need to start thinking about how im gonna tune it, i know its pretty easy and i just need a distrubutor, ecu, and a wire harness i believe, but i wanna know if i could get the parts from the junkyard? what year civics/integras have the distributor and ecu i need? and is there anything else im missing?
Re: 91 integra obd 0 to 1 conversion
You will need a '94-01 Integra or CRV distributor, an OBD-0 -> OBD-1 ECU adapter, modify the fuel injector plugs for your new 550's and then a distributor conversion adapter to go from OBD-0 -> OBD-X ("X" depends on what year distributor you get). You will NOT have to change the chassis or engine harness... and this is lucky for you since nothing else just "plugs in".
