91 integra ls starting problems
Old Mar 24, 2009 | 01:10 PM
808DA's Avatar
Default 91 integra ls starting problems
this just started a week ago. when i start my car, sometimes it starts right away, but most times it doesnt want to start. it cranks but it wont start. in order for me to get it started, i would need to step on the gas pedal while cranking the car, then eventually it starts up. for the first few seconds after its started, i can smell gasoline but it goes away after. the car runs fine with no hesitation whatsoever. no check engine light also. can anybody point me to the right direction on what to check before i start replacing parts? thanks in advance
Old Mar 24, 2009 | 01:21 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: 91 integra ls starting problems
Fuel pump or starter! start with the fuel pump my guess starts there!
Old Mar 24, 2009 | 02:02 PM
capn's Avatar
If you can smell fuel, it might be clogged/leaky/stuck injectors and it might be flooding the engine. Other than that just cover your bases, make sure there isn't anything outta place.
Old Mar 24, 2009 | 03:05 PM
808DA's Avatar
could the fuel smell be caused by stepping on the gas pedal while starting it, therefore causing it to flood? just a thought. i will check the voltage drop on the starter next, i ruled out the main relay because its ok according to the relay diagnostics i found on the sticky above.
E Swift
Jul 10, 2019 03:46 PM
KevinEvo
Aug 17, 2010 08:08 PM
aznlangjai
Apr 15, 2009 01:59 PM
IntegraPir4te
Mar 19, 2007 10:51 AM
