9006 to 9005 headlight conversion.
watts = measurement of power consumed.
lumes = measurement of light output.
so if you have 10,000 watt bulbs that are still 1500 lumens, its better to get silverstarts which are 1700 lumens and only 60 watts
http://www.sylvania.com/auto/silverstar.htm
I did, its great.
I did, its great.
I did, its great.
I did, its great.
compare that to the 9004 headlights my old car used, as well as G2 Integras, 700 lumens output on the low beam (45W).
Guy thanks alot...i guess you just solved my problem.
I just thought about it as like changing the light bulb in your house. usually when you get the higher watt bulb the brighter it gets.
I'll keep u updated when i get some bulbs.
Just to be clear this mod replaces your low beam bulbs with what were originally meant to be high beam bulbs, correct?
Sylvania lists 9006 for the low beams and 9005 for the high beams.
-allen
Boosted_JDM
Feb 12, 2007 08:26 AM
