9005 silverstar conversion
Old May 4, 2002 | 12:09 PM
acatak's Avatar
Default 9005 silverstar conversion
If you do the 9005 conversion, do you have to aim the lights a certian way like it says to at that page? or is that only for BMW's?
Old May 4, 2002 | 12:14 PM
jgrotkier's Avatar
Default Re: 9005 silverstar conversion (acatak)
you should be fine, but if you get people blinking you all the time you might want to aim them down a little
Old May 4, 2002 | 02:13 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: 9005 silverstar conversion (krrrrrrzyrebel)
you should aim them like stock, which means the cutoff beam on a wall should be an inch or two below the height of the headlight from the ground.
Old May 4, 2002 | 06:23 PM
acatak's Avatar
Default Re: 9005 silverstar conversion (PatrickGSR94)
how do you aim them down?
Old May 4, 2002 | 07:07 PM
Sintegra's Avatar
Default 9005 conversion
what is the bmw 9005 conversion link?
the search function doesn't work
Old May 4, 2002 | 11:21 PM
Community Builder
Default Re: 9005 conversion (Sintegra)
in my sig
Old May 7, 2002 | 02:59 AM
Dirt's Avatar
Default Re: 9005 conversion (PatrickGSR94)
Did you all add more O-rings to the new converted bulb like the site says?
I'm contemplating 9006 PIAA Xtreme vs. converted 9005 Xtreme. Is the converted 9005 going to be overkill for oncoming drivers?
I finally had a low beam PIAA 9006 Platinum burn out after 3 years of use.
Old May 7, 2002 | 07:02 AM
mikeeee's Avatar
Default Re: 9005 conversion (Velvet Jones)
Velvet Jones,
Definetely install the extra rings from your old set of bulbs. The 9005's are of a slightly smaller diameter than the 9006's, and thus, their o-ring is not big enough to seal off the lamp enclosure. I found this out two days after installing 9005's and having driven in a rain storm. The next day I had two very wet headlight enclosures.
I used a shop vac to suck all the moisture out. I had to run it for about 45 minutes, but all is good now. I installed the second set of o-rings, and have had no further moisture problems, driving through smaller showers of rain.
Mike
ac_attak
Aug 1, 2007 04:46 AM
CNSK
Nov 8, 2004 06:58 AM
Train
Apr 8, 2004 06:51 AM
shipsaeki
Mar 3, 2003 06:00 PM
