90 integra not starting...
Old Oct 21, 2007 | 07:49 AM
rice a roni's Avatar
Default 90 integra not starting...
after letting the integra sit for a while it wont start...there is no way i can check for spark until monday so thats a no no...i cant hear the fuel pump so i decided to take the fuel pressure regulator off and see if fuel would come out with the key on...should fuel come out or shouldnt fuel come out?
Old Oct 21, 2007 | 08:06 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
well if the pump is still building pressure, it def should spray out. check the main relay?
Old Oct 21, 2007 | 12:56 PM
Default Re: (ComeOnKip)
already checked the main relay...resistance is 0 ohms. i also read that there is a second relay that controls the fuel pump and that lies within the ecu its self...another thing is that water has been leaking from the blower motor housing and carpet is well...soaked...could the ecu have shorted out?
another thing is that i replaced the fuel pump the other week so i dont think it should've died unless i did something wrong which i feel that i didnt...it was simple enough, two connections on the pump, one positive side one negative side and a fuel hose. there were no leaks.
should i try an ecu? is there a way i could jump my fuel pump to see if it would work?
Old Oct 23, 2007 | 09:34 AM
Default Re: (rice a roni)
ok so i checked for spark and there is spark...
is there a way i could jump the fuel pump to see if it is working? how can you tell if the pump is working if you cant hear it? my integra is the only car i cant hear the pump in even when it is working.
Hanmin
Sep 14, 2009 09:29 AM
teknohatchie91
Apr 15, 2009 11:40 AM
iNDyCRX
Apr 24, 2008 12:54 PM
tegturbo
Aug 11, 2005 04:18 PM
SLOW4drINTEG
Jul 30, 2003 07:09 AM
