'90 DA Idle Problem: HELP
Old Nov 24, 2006 | 01:31 PM
RansteadSpecial's Avatar
Default '90 DA Idle Problem: HELP
Stock '90 DA, idle goes up and down from 900 to 1600 rpm. Plugs good, wires next to check. Air problem? What to do? Thanks
Old Nov 24, 2006 | 03:54 PM
gsrman171's Avatar
check for broken vacume hoses, the wires to the O2 sensor,a dn check for cells.
Old Nov 24, 2006 | 04:12 PM
Fat Chick Magnet's Avatar
maybe your ICV (idle control valve) is messed up.
Old Nov 25, 2006 | 08:58 PM
autopro01's Avatar
Default Re: '90 DA Idle Problem: HELP (RansteadSpecial)
hey wats up its the sensor connected to the throttle body. you can disconnect it but u will have to let it warm up in the morning so idle will settle. but if u want to replace. It costs 450 from acura because it only comes together w/ throttle body
Old Dec 2, 2006 | 06:42 PM
Default Re: '90 DA Idle Problem: HELP (autopro01)
thanks alot, im trying all these
Old Dec 2, 2006 | 07:19 PM
GRAF-FITI's Avatar
* B A N N E D *
get a can of carb cleaner and spray the vaccuum hoses in small increments....if the idle kicks up then that is where the vaccuum leak is....my theory tho, if this doesn't turn anything up, is also the IACV
Old Dec 2, 2006 | 07:21 PM
bigbucksGSR's Avatar
it could be a few things. throttle position sensor, map sensor, or a vacum leak. it shouldnt be plugs or wires. maybe dizzy but unlikely. go to a junk yard and steal a bunch of tps and map sensors. thats what i did and it fixed it. it was my map sensor but i wasnt flashing a code but that fixed it.
Old Dec 3, 2006 | 05:54 AM
Duane_in_Japan's Avatar
Go check out "idle revs" in the accord section. Its active now, page 1 or 2.
Old Dec 3, 2006 | 08:44 AM
dc4_wHORE's Avatar
Soldering Iron Wizardry
That sensor on the TB is a Throttle Position sensor (TPS) I have the same problem with my 2000 DC2, I called password JDM and got them to send me a used TPS, i ground off the rivits on the OE TPS, and replaced it with allen screws.
Turns out my problem was with the IACV (idle air control valve) but if you buy one, get a OE from Acura, i bought one from autozone.. and it was bad when i got it ($190 wasted)
elli
Jun 1, 2010 01:22 PM
CRX-SIR
Sep 20, 2004 06:00 PM
CA6VTEC
Sep 14, 2004 05:57 PM
OneFastGsr
Oct 8, 2003 08:30 AM
Vp Special K
Apr 4, 2003 09:14 PM
