5 Lug Conversion
Old Dec 4, 2004 | 05:02 PM
mikey1987's Avatar
Default 5 Lug Conversion
In a B18C5 motor swap in an LS:
would you have to change to 5 lug from the LS 4 lug?
will the axles from a Type R bolt up to the suspension on an LS?
Also, could i in theory, get coilovers and brakes, on an LS, then swap in the Type R motor with no problem?
is there any info i should know about this swap?
Old Dec 4, 2004 | 05:11 PM
rovigian's Avatar
Default Re: 5 Lug Conversion (mikey1987)
This belonds in the hybrid forum, but here is your answer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikey1987 &raquo;</TD></TR><TR><TD CLASS="quote">In a B18C5 motor swap in an LS:
Nope
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
will the axles from a Type R bolt up to the suspension on an LS?</TD></TR></TABLE>
Yeah, they are the same
Yep<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
is there any info i should know about this swap?</TD></TR></TABLE>
Just wire vtec, it's an easy swap
Old Dec 4, 2004 | 06:09 PM
MR5sARECOOL's Avatar
Default Re: 5 Lug Conversion (rovigian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rovigian &raquo;</TD></TR><TR><TD CLASS="quote"> This belonds in the hybrid forum, but here is your answer
Nope
Yep
Just wire vtec, it's an easy swap</TD></TR></TABLE>
Old Dec 4, 2004 | 07:05 PM
dFreezy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rovigian &raquo;</TD></TR><TR><TD CLASS="quote"> This belonds in the hybrid forum, but here is your answer </TD></TR></TABLE>good responses but the hybrid forum is swaps between series, so this is the appropriate forum
Old Dec 5, 2004 | 01:45 PM
mikey1987's Avatar
so i dont need to convert to 5 lug even if i am getting the Type R axles?
i read somewhere that JDM Type R axles are 36mm long and the USDM integra's are 32mm.
I'd be getting a JDM motor with JDM ITR axles bolting up to a stock LS? sound kosher or sounds like i need 5 lugs?
Old Dec 5, 2004 | 04:09 PM
Bl6da9's Avatar
Use your original LS axels they will work with the B18c -R. You are correct JDM ITR axels are 36mm and they will not work on your stock O.E.M HUB. I run the JDM ITR axels with the JDM ITR 5 lug on my DA teg.
Old Dec 19, 2004 | 11:26 PM
dc24me's Avatar
us is 32mm, as well as ctrs and the 96 spec ITR
jdm itr 98+ spec is 36mm. (because of the bigger 16" wheels)
crvs are 36mm too.
NINE9DC4
10
Sep 11, 2008 03:28 PM
EMTWIZZLE
Honda Civic (2001 - 2005)
Feb 24, 2007 12:29 PM
mikey1987
Dec 8, 2004 01:38 AM
b18bme
Sep 1, 2004 12:09 PM
civictyper99
22
Jul 25, 2003 10:48 AM
