3inch Intake
Old Jan 31, 2004 | 02:47 PM
BLK99VTECR's Avatar
Default 3inch Intake
who makes an 3inch short ram intake that will fit a GSR T/B
Old Jan 31, 2004 | 03:04 PM
Kendall's Avatar
Just buy a 3 inch intake and get a silicone adapter hose, or a good hose clamp.
Old Jan 31, 2004 | 06:55 PM
96dc2's Avatar
Default Re: 3inch Intake (BLK99VTECR)
Do you still have the GS-R IM also? I have a Weapon-R shortam that is 3". The only other intake I know that is 3" Mr. Gasket.
If you have a Skunk2 IM, then most ITR intakes will be 3".
Old Jan 31, 2004 | 08:13 PM
Tweakmeister's Avatar
go on to JC Whitney or any of those bulk discounters and buy a u-bend piece of pipe...then just cut to fit.
no point going 3" with a shortram unless your motor is built....you'll lose torque.
Old Jan 31, 2004 | 10:03 PM
mugenracer's Avatar
I had a 3" short ram intake and then changed to a 2.75" CAI, i took the cold air section of for the winter and ran it as a short ram, and it felt way stronger than it did with the 3" intake. the car seemed to bog at low revs as i suspect it wasnt able to pull the air in fast enough thru the 3" pipe.
Old Feb 14, 2004 | 04:09 AM
BLK99VTECR's Avatar
so would the AEM ITR CAI connect to a Skunk2 IM wit GSR throttle body?
T Niggs
Jan 21, 2009 08:48 AM
drg1989
Dec 3, 2007 06:56 AM
AndrewCJ
Jun 3, 2006 11:22 AM
danteisme
21
Dec 17, 2005 03:27 PM
katb16vo
Mar 18, 2004 06:55 PM
