2nd gear shift
Old Jul 30, 2003 | 04:45 PM
RacerXintegra2k's Avatar
Default 2nd gear shift
Is it just my teg or when going from 1 to 2 that shift is pretty rough. kinda notchy not smooth like 2nd to 3rd or 3rd to 4th ? i've heard other teg owners with same problem or is it just a worn syncro ?
Old Jul 30, 2003 | 04:48 PM
Wave's Avatar
Default Re: 2nd gear shift (RacerXintegra2k)
I have the same feeling too. Also, I feel rather difficult to shift from 2nd to 1st when the car is in motion, even when the car is just rolling slowly. I hope this is normal.
Old Jul 30, 2003 | 04:56 PM
Tweakmeister's Avatar
Default Re: 2nd gear shift (01GSRNBP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01GSRNBP &raquo;</TD></TR><TR><TD CLASS="quote">I have the same feeling too. Also, I feel rather difficult to shift from 2nd to 1st when the car is in motion, even when the car is just rolling slowly. I hope this is normal. </TD></TR></TABLE>
Quite normal. you'll have to rev-match when downshifting, especially into 1st (blip the throttle...hard).
Most Integras I've seen and driven have a somewhat notchy 2nd. Heck, the new RSX's "suffer" the same "problem."
Old Jul 30, 2003 | 04:57 PM
AWDxBOOST's Avatar
Default Re: 2nd gear shift (Tweakmeister)
yea its bumpy...at least it doesnt grind like a fast shift into 3rd
Old Jul 30, 2003 | 06:05 PM
LSTEG96's Avatar
wow... i thought the synrcos were bad... ive tried everything to get rid of this problem!!! the grind into 3rd isnt THAT bad is it??
Old Jul 30, 2003 | 06:08 PM
DA-MAX's Avatar
Default Re: 2nd gear shift (ls_teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls_teg &raquo;</TD></TR><TR><TD CLASS="quote">at least it doesnt grind like a fast shift into 3rd </TD></TR></TABLE>
don't remind me.....
AWDxBOOST's Avatar
Default Re: (LSTEG96)
no...it grinds in 3rd cause 3rd gear only uses one synchro
Old Jul 30, 2003 | 09:01 PM
LSTEG96's Avatar
does anyone notice a bump between 1st and second?? like.. where neutral is. You might need to have an after market shifter to feel this
Old Jul 30, 2003 | 09:30 PM
IntegraLova's Avatar
I know that bump between 1st and second. its like if you go straight down as far left as possible, the shifter will stop but you wont be in gear.
Old Jul 30, 2003 | 10:11 PM
integraL's Avatar
Default Re: (IntegraLova)
i don't know if you guys experience this, but when i'm in neutral and shift to 1st, at times it only goes half way up. it gets stuck aftergoing to the left and halfway up. so i have to put it back in neutral and shift back to 1st. its probably just mine. just interested if it happens to anyone else...
Old Jul 30, 2003 | 11:00 PM
Vtecfool's Avatar
Default Re: (integraL)
i had that same problem before, but i installed the skunk2 short shifter and it's all smooth now.
Old Jul 31, 2003 | 02:47 AM
AutoMan's Avatar
i have that problem with my 2nd to 3rd...
anything pasted 3k its grinds....SUCKs
Old Jul 31, 2003 | 04:38 AM
Wave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraL &raquo;</TD></TR><TR><TD CLASS="quote">i don't know if you guys experience this, but when i'm in neutral and shift to 1st, at times it only goes half way up. it gets stuck aftergoing to the left and halfway up. so i have to put it back in neutral and shift back to 1st. its probably just mine. just interested if it happens to anyone else...</TD></TR></TABLE>
I have the same problem too. It is very annoying. Sometimes whenever it is green light and I can't shift into 1st, it stuck half way, I have to either shift to 2nd or put it back to neutral and re-shift to 1st. Makes people think that I am stupid or something that the light is green and I am not moving.
Old Jul 31, 2003 | 06:41 AM
TGUNNER's Avatar
Default Re: (ls_teg)
no. it grinds bc either the syncro is shot or its just bad driving.
Old Jul 31, 2003 | 07:19 AM
Default Re: (TGUNNER)
i have that half way into 1st shift to GOD is it annoying and always causes me to do a burn out when i do get it in cause i feel so frustrated.
Old Aug 1, 2003 | 02:02 PM
integraL's Avatar
Default Re: (RacerXintegra2k)
haha so it isnt just me? did someone say its a broken synchro? sorry to steal the thread
Old Aug 1, 2003 | 02:06 PM
VSM3point5genDC4's Avatar
Shifting into first is weird in ALL Hondas... 1rst gear and reverse are not synchronized, and to make an easier shift pop the clutch pedal down a little more than half way instead of all the way down and you will find it shifts into first much more easily.
As far as the first to second gear bumpiness, you just have to give alot of gas into 2nd from first than you would think, its touchy, but if you do it right, it is smooth, i get this same problem but much milder from 2nd to 3rd as well.
Kowalske
Honda Civic (2001 - 2005)
Dec 4, 2006 11:44 AM
ALL IMPORT
Sep 1, 2006 08:01 PM
98BabiGs-T
Apr 18, 2006 02:20 PM
buzlink
Nov 19, 2005 05:03 PM
SKDRCR
Aug 21, 2003 07:50 AM
