1st gear hard to get into...
I have a 94 Gs-R and lately it's hard to go into first. Like I'll be driving to a stop sign and I'll be in 2 or 3 and I down shift to 1st, it seems to be locking and what not, do all Teg have auto-locking on 1st gear?
Re: 1st gear hard to get into... (94BabiGs-R)
humm...i never go back to first untill im at a complete stop. but yeah it shouldn't let you go back to frist from any gear unless your down to speed. saves you from accidentally down shifting from 5th to 1st...
Re: 1st gear hard to get into... (FlatBlackTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg »</TD></TR><TR><TD CLASS="quote">^Yep.
Is it fine to shift into first from a stop?</TD></TR></TABLE>
yes, it is.
yes, it is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">you can't downshift into 1st... in any car </TD></TR></TABLE>
Bullshit. I downshit to first alot in my DA with a LS transmission when autocrossing on tight courses.
Pretty much should only be in first if you're going from a dead stop. If it's hard to get into first from a dead stop, you can try to clutch twice and then shift or put it into like fourth and then first
Hype-R Stalker
Re: (94BabiGs-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94BabiGs-R »</TD></TR><TR><TD CLASS="quote">Well I was down to speed, literally came to a complete stop.</TD></TR></TABLE>
Is it random, or All the time?
try pushing it into 3rd or 4th real quick then try 1st again.
Re: 1st gear hard to get into... (dohcMONSTER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcMONSTER »</TD></TR><TR><TD CLASS="quote">you can't downshift into 1st... in any car</TD></TR></TABLE>
and why not????
and why not????
Re: (FlatBlackTeg)
try pushing it into 3rd or 4th real quick then try 1st again.</TD></TR></TABLE>
Most of the time and they seem pretty random.
Re: (94BabiGs-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsDAteg »</TD></TR><TR><TD CLASS="quote">Bullshit. I downshit to first alot in my DA with a LS transmission when autocrossing on tight courses. </TD></TR></TABLE>
Agreed. I sometimes have problems shifting into first when at a stop so I do it when slowing down.
Re: (GsDAteg)
yup, i do it all the time, if im under 20mph. obviousy you cant slam it in there but if you gentky put in in 1st it will go fine. ive done that in several cars
the more concise way to put it is that you can't downshift into first easily like you would any other gear.
You'll need to double clutch and revmatch correctly for it to slip in smoothly.
but you really shouldn't ever need to downshift into first on the streets. AutoX/RR is another story.
i have a 95 gsr and it does this to me every so often...sometimes i can be stopped at a light for a mintue and it doesn't want to go into first. my clutch was just changed in october
Re: (SpoonSirG)
I too ahve trounble shiffting smoothly into first but it can be done. *** for getting into first at a dead stop its s HONDA thing. I have talked to numerous mech from honda/acura and all u have to do is hit reverse than it should slide right into first and vis versa goin into reverse
