2001 integra running poorly
Old Apr 9, 2012 | 08:22 AM
xpddc4's Avatar
Default 2001 integra running poorly
I bought this integra ls auto not to long ago... and still isn't running right
I changed the o2,thermostat,plugs wire, plugs,cap, rotor, fuel filter.
Still having shake downs at idle and it fluctuates. But it only does it once in a while now. Not throwing anymore codes.
I tried to smog it today and said it failed MIL/CHECK engine light but it hasn't came on in over a week and went off by its self I didn't try to clear it.
What else should I look into, to fix this annoying problem?
Thanks
Old Apr 9, 2012 | 08:26 AM
DELshaneSOL's Avatar
Default Re: 2001 integra running shitty
Does it do it cold and warm or on of the other?
Old Apr 9, 2012 | 08:37 AM
xpddc4's Avatar
Never does when I first start it up. So I would say it does it when its warm but it never overheats
Old Apr 9, 2012 | 08:40 AM
xpddc4's Avatar
Is that quote for me or is that just random. Sorry im a noob on here.
Old Apr 9, 2012 | 08:43 AM
Dc4LsTeG's Avatar
EK9
Lol that's just his sig. not for you. Does your cel come on then go off when you turn your key on?
Old Apr 9, 2012 | 08:44 AM
kyden's Avatar
if it failed for a CEL, what is the code? just because the light isn't on doesn't mean there isn't a code stored.
Old Apr 9, 2012 | 11:15 AM
xpddc4's Avatar
the light comes on for like 3 sec when i put the keys in, but turns off... I don't know the codes off hand my mechanic said it was a misfire multiple cylinders we did the whole tune up thing then i got check engine light again he said it was o2 sensor so we changed the fuel filter and o2 put a denso in there. I'll ask what the codes were though.
Old Apr 11, 2012 | 10:18 AM
xpddc4's Avatar
do you think its the ecu? my check engine light came on again but don't have a code reader.
Old Apr 11, 2012 | 12:47 PM
Coney's Avatar
go to autozone. they will pull the code(s) for free. then post them up here
Old Apr 11, 2012 | 02:23 PM
xpddc4's Avatar
i would but they dont do that here in CA. I just ordered a bluetooth obd2. I am going to hook it up to my phone and find out the codes. I post again once i receive it.
oh and if i need a new ecu which one to get? they say p75 a5 __ works for 96-99
i never see anything about 00 01 years is it the same?
Old Apr 11, 2012 | 04:23 PM
Jdm-db7's Avatar
u dont need a code reader... there will be a blue plug on the passenger side with 2 holes in it... get a paper clip and put it in both the holes to connect them... then turn ur key all the way forward and the check light will blink and the slow blinks will be first and those are the 10's and the fast blinks will be second and those are the ones... in example it will blink twice slowly then 4 times fast... that would be 24... then look up the codes on the internet or the honda app if u have a droid phone
Old Apr 12, 2012 | 12:02 PM
collkid's Avatar
This is cool. Who knew. What does it do if there is no codes?
Old Apr 12, 2012 | 07:02 PM
el crapitan's Avatar
not for obd2. you have to jump 2 of the pins on the 16 pin datalink connector.
can't remember which 2, but if you google it, you'll find it.
get the codes and post them in their entirety.
Old Apr 13, 2012 | 06:08 AM
kyden's Avatar
^^ obd2 has the same connector on the right side of the dash as obd1.
Old Apr 13, 2012 | 07:34 PM
that connector isn't used to pull codes though
Old Apr 13, 2012 | 10:07 PM
TYLER3's Avatar
It's still works and tells you the code so you don't have to go anywhere or buy a code reader...
Old Apr 19, 2012 | 07:08 PM
xpddc4's Avatar
Ok the only code its doing now is p1399 which isnt a acura/honda code from what a read.
but its missfiring like crazy. i am smelling a burning rubber smell. think its my timing? injectors? some type of sensor? any suggestions?
Old Apr 20, 2012 | 12:46 PM
xpddc4's Avatar
happy 4dub! bumb! anybody? do u guys think its the whole distributor
Old Apr 24, 2012 | 08:51 AM
xpddc4's Avatar
Took it to the shop was a timing belt. Case Closed. so if you get the code p1399 check ur timing belt. Thanks to all the people who tried helping me.
Old Apr 27, 2012 | 09:36 AM
xpddc4's Avatar
Default Re: 2001 integra running poorly
well i guess the problem is still there. Case OPEN.
Changed:
plugs
wires
cap rotor whole dizzy brand new
o2 sensor
fuel filter
thermostat
timing belt
it has good compression 150 150 165 170
its weird it runs good with new plugs for like 20 miles or so. then goes back to crap. switched the spark plug from cylinder 2 and put it in cylinder 1 and it started running good again. there was no wear on the plugs they both looked the same. no oil nada. so i think it might be the injectors? you guys been sleeping on this thread help me out. any ideas? oh and when i dropped off my car to do that timing he said 2 of the plug wires were melted so he replace the wires and plugs again. he offer to show me them but i said its ok. idk if he was blowing smoke up my *** or what.
Old Apr 27, 2012 | 09:38 AM
xpddc4's Avatar
and when i pull the plug off the first cylinder when its running poorly. it pretty much runs the same but i can hear the spark plug firing.
Old Apr 27, 2012 | 10:09 AM
mhax's Avatar
I would try to change the fuel pressure regulator.
Old Apr 27, 2012 | 10:21 AM
B20ztek's Avatar
Thats a terrible idea you could fry your distributor doing that.. also you can't "hear" your plugs firing lol I assume you mean you can see it.
I would check your timing, also fuel pressure.
Nate13
Jun 5, 2009 06:51 AM
Berge9798
May 27, 2008 10:10 AM
JDM-EJ1
Apr 5, 2005 11:55 AM
lilxvtecxpwr
Oct 13, 2002 11:04 PM
