2.5" cat solution
Old Nov 4, 2013 | 04:34 PM
EJ25er's Avatar
Default 2.5" cat solution
a few weeks ago I ordered my WS2 exhaust, and skunk2 tri-y(alpha series) Im looking for a solution to stock cat, I have yet to find an ITR (jdm) cat which is my first preference, what are my other options? I ordered a magnaflow hi flow while waiting for the other parts to get here, it arrived first and is stock piping; could i cut the piping use the cat? or are the cat internals going to choke it no matter what
before suggesting test pipes, I have one coming w/ the header /exhaust but would really rather use a cat, i dont like black butts and I can not tell a lie.
Old Nov 4, 2013 | 07:01 PM
B_Swapped93's Avatar
Default Re: 2.5" cat solution
get an adjustable test pipe from PLM OR BWR
Old Nov 5, 2013 | 07:22 AM
EJ25er's Avatar
I have the blox adjustable, but don't want to run w/o a cat.
I know there are cel fixes available, just don't want to risk the fine for no cat.
Old Nov 5, 2013 | 08:01 AM
Barf Hat's Avatar
I have almost the same set up as you. I'm running a full WS2 cat back and DC tri-y. I have a magnaflow 2.5" highflow too. To mount it I just cut the flanges and added about 3/4 of an inch on each side of the cat and then remounted the flanges. It was super easy and if you dont have the equipment to do it just go to midas its an easy fix.
Old Nov 5, 2013 | 08:26 AM
EJ25er's Avatar
Both bungs fit w/o extending ?
Old Nov 5, 2013 | 09:49 AM
Barf Hat's Avatar
Both bungs, is yours OBDII? I have a 95 so theres only one O2 sensor and it fit right up theres a little wiggle room with the sensor wires atleast there was for me.
Old Nov 5, 2013 | 02:01 PM
EJ25er's Avatar
Ahh, I've ordered2.5 mag flow, I'll be welding it to te blox test pipe I got, just need to figure out measurements on how much longer then stock the s2 header is.
Old Nov 8, 2013 | 05:30 PM
safedriver's Avatar
I bought a 2 1/2" cat from SMSP (Dave) a couple of years ago.
The JDM cat is 9 nickels shorter (7/8") than my USDM cat.
I bought it for my JDM ITR header, with its 2 1/2" collector.
I put a stack of 9 nickels on top of the SMSP cat, in this photo.
JDM00SI
Oct 15, 2005 09:14 PM
sohcvtec66
21
Apr 27, 2004 10:03 PM
blu2ksi
Jan 15, 2004 12:57 PM
Type RS
Apr 1, 2003 12:27 PM
Anubyss
Aug 2, 2002 09:49 PM
