1996 with a VSS problem
Old Sep 26, 2013 | 11:29 AM
xesvuli420's Avatar
Default 1996 with a VSS problem
Is there any way I could have damaged the mechanical part of the VSS by changing a clutch? I had a hard time getting the tranny back on, and once I did, the VSS hasn't worked since. I took the sensor off, and was about to buy another one, but it just seems odd to have went bad just sitting there.
My speedo and Odo dont move but my tach does, and I verified its not the gauge by datalogging. Hondata says the vehicle is always moving 5mph.
What do you guys think?
Is there a way to test this guy?
Could I have broke something or misaligned something trying to line the tranny back up?
Thanks guys
Old Sep 26, 2013 | 11:34 AM
kyden's Avatar
Default Re: 1996 with a VSS problem
the pins usually corrode. have you looked at it?
Old Sep 26, 2013 | 12:42 PM
xesvuli420's Avatar
Pins look good.
While the car was down getting the clutch installed I also swapped out the ecu… Could it be the ecu?
Old Sep 26, 2013 | 12:44 PM
xesvuli420's Avatar
I just don't understand how I can park the car and everything work, then when I move the car again a sensor be bad
send2artem
Apr 3, 2012 09:30 PM
blackep925
Jun 18, 2008 02:28 PM
bg-33p
Feb 12, 2005 10:33 PM
chrysler kid
Oct 9, 2004 10:50 PM
92LudeSI
Dec 10, 2003 07:24 AM
