1990 LS?
Old Dec 26, 2007 | 09:11 AM
smokedup's Avatar
Default 1990 LS?
I post earlier that i bought a DA,, ok so i wanted some cheap vtec in that bitch, thinkin about a b16, do you think the body would bring the performance down just a tad bit because of weight? [keep in mind i did not check the stats on the original b16 vehicle and the DA] should i keep the LS fix and build it? theirs a big oil leak
Old Dec 26, 2007 | 09:29 AM
WinningNinja's Avatar
Default Re: 1990 LS? (smokedup)
I hope this helps.
https://honda-tech.com/zerothread?id=642479
I know this is in the Civic section, but they have a swap section on the bottom comparing and contrasting B16 vs B18.
Also the following link has a engine, general information and swaps section, which can hopefully help you.
https://honda-tech.com/zerothread/1230496
It is easier to get help if you use better grammar, and some sort of structure to your sentences.
This is a very helpful site:
http://grammar.ccc.commnet.edu/grammar/
Old Dec 26, 2007 | 09:35 AM
smokedup's Avatar
Default Re: 1990 LS? (WinningNinja)
i dont kno but i think everybody can understand. anyway, thanks for the links bro.
Old Dec 26, 2007 | 09:36 AM
jhammond_82's Avatar
Reject Papi
wow ninja!! 25 posts and learning already, as for smokedup, maybe thats the problem. use the search button at the top right of the screen, its red. as for the b16 swap, its been done a million times, you should fix your oil leak and boost that thing, or ls/vtec. thats just my 2 cents.
Old Dec 26, 2007 | 10:33 AM
dmpd_ef's Avatar
Default Re: 1990 LS? (jhammond_82)
if you can find a b16 with the right tranny that would be nice. it would be about as fast as a 99-00 si wich isnt too bad, the reliability of a stock b16 vs a boosted ls or ls-v is also one of the reasons i kinda wanna go that route as well. and you have the lovely sound of v-tak to put a smile on your face
Old Dec 29, 2007 | 09:32 AM
smokedup's Avatar
Default Re: 1990 LS? (dmpd_ef)
yehh basiclly i piked it up it has a b16 tranny wit a b18a1, so i dont think a b16 will be too bad
bbrian
39
Aug 4, 2012 05:48 AM
Hatchieman
Jan 25, 2009 04:52 PM
itsmebeaner1987
27
Aug 17, 2004 10:48 PM
straightline
Mar 22, 2003 07:07 AM
Lookincrazy
Mar 10, 2002 12:38 AM
