1990 B18A1 Integra Code 4
Old Feb 19, 2012 | 05:15 AM
TheEricNielsen's Avatar
Default 1990 B18A1 Integra Code 4
I just replaced the cv axles yesterday the car was running great until I was almost home and then about 2 blocks from the house it started to hiccup and the CEL came on. I got it to the house and yanked up the passenger floor mat to find that it was throwing a code 4. Crank position sensor, I believe?
The car is running extremely rich, and doesn't feel healthy.
What should I do?
Old Feb 19, 2012 | 06:29 AM
emd513's Avatar
Default Re: 1990 B18A1 Integra Code 4
That model doesnt have one. Peobably looking at a bad map sensor or a vacuum line thats come off. Since its running rich. If the sensor is bad there about 250 at autozone. Or take one off another tegg. My 90 n 92 are the same.
fcm's Avatar
fcm
Old Fart
Check the crank position sensor and it's wiring...
Size:  48.3 KB 94
Old Feb 19, 2012 | 08:53 AM
el crapitan's Avatar
it's probably going to need a distributor, as the ckp resides in it and is non-serviceable. also, 85% of the time, with these da's, any ignition related issue is the distributor.
run through the flow chart though that fcm has provided. but chances are that is the problem
Old Feb 21, 2012 | 08:08 AM
I've ordered a new dizzy. It'll be in today.
You guys are awesome, much thanks.
Will keep everyone updated.
Old Feb 21, 2012 | 08:09 AM
Also, it wouldn't go over 3100 revs.
I don't know if that helps.
Old Feb 21, 2012 | 10:48 AM
stocker2shocker91's Avatar
I requested a short story for a title.
looks like it might have been in safe mode as well, unfortuantely older integra dizzys are not the greatest. I have had many fail
Old Feb 21, 2012 | 12:37 PM
I just replaced the dizzy and now the codes are gone and it revs. However, it has trouble at idle and almost sounds like a WRX.
Old Feb 21, 2012 | 03:50 PM
fcm's Avatar
fcm
Old Fart
Check the timing. 94
Old Feb 22, 2012 | 04:29 AM
The timing was just "done" by a couple guys I had come over. They told me that the reason it's running like that is the iac valve. I'm not at all convinced.
Old Feb 22, 2012 | 05:05 AM
did they use a timing light?
Old Feb 22, 2012 | 06:34 AM
They attempted to use a light but then just lined everything up to #1 cylinder TDC, then lined up the cam sprockets to the markings then used screwdrivers to hold the cams in place and tightened down the tensioner.
Old Feb 22, 2012 | 06:56 AM
fcm's Avatar
fcm
Old Fart
That is valve timing, how about ign. timing?
You installed a new distributor, you need to "adjust" ign. timing, even if it is not your problem. 94
Old Mar 3, 2012 | 02:35 PM
The timing was correct. Cylinder #3 is only at 30psi. Could that be piston rings that are messed up?
Old Mar 3, 2012 | 02:43 PM
omarmm90's Avatar
sorry for interrupting this post but I'm new so they won't allow me to create my own post but does anyone know a good website to get a ac friendly turbo for my 98 integra ls
Old Mar 3, 2012 | 07:28 PM
what did the other cylinders read?
if the rest read ok, try pouring a teaspoon of oil down that cylinder prior to the compression test.
if the rest also read bad, it sounds like your friends may have bunged up the timing belt adjustment
check the forced induction section
Old Mar 7, 2012 | 05:41 AM
nuggets's Avatar
and updates on this issue? I'm curious to see the outcome..
Shikaido2004
Jul 31, 2008 08:50 AM
11SecCrx
Jan 7, 2008 08:32 PM
sloweh3
Oct 21, 2003 08:17 PM
Eluzion
Jun 20, 2003 12:08 PM
mraudio13
Sep 19, 2002 05:34 PM
