00 integra idle problem
Old Feb 15, 2009 | 08:02 PM
gsrjdm00's Avatar
Default 00 integra idle problem
hey guys really need help getting stump with idle problem. the problem is when i first start the car the would warm up normal around 1500 rpm, after about 10 minutes the idle would go higher, to 1800 and stay, so i adjusted the tps and the idle would drop to 1100 rpm, when i rev it up the idle would drop to 900 rpm and go back up to 1100. the weird thing is that when i drive i would be driving and shift to nuetral the idle would drop to 900 and then bounce back up to 1300, when i stop completely then it would drop to 1000 to 900 rpm. i don't get really need help begging, i replaced the tps, tested and cleaned iacv, don't know what the problem is.
Old Feb 16, 2009 | 08:38 PM
usd-ls-v's Avatar
Default Re: 00 integra idle problem
did you check your cable adjustment, this happened to me and i found the throtle cable was sticking. when i idles funny pull back on the throtle and make sure its all the way closed.
Old Feb 16, 2009 | 09:48 PM
Circuit Star-29's Avatar
Well, what have you done to the car that might affect your idle? Change vacuum hoses, or coolant... could be a couple different things.
ge_itr
Oct 16, 2007 05:12 PM
ashe
Aug 6, 2003 11:18 AM
ashe
Aug 4, 2003 07:39 AM
