** How To - Leakdown Test **
Old Jan 12, 2006 | 12:52 PM
wildoutwhitegsr's Avatar
Default ** How-To/DIY ** - Leakdown Test
What is a leakdown test? Well a leak down test determines exactly how much compression your losing and from which cylinder, as well as the cause of it. More on that later. This test along with a compression test will determine the health of your motor.
Tools Needed:
Compressor
5/8” Spark Plug Socket
10mm
19mm
Rachet
6” Extension
Leakdown Tester
1) First things first, find a place to work on your car.
2) Proceed to plug in your compressor and set it up with the hose attached and pressure regulated between 60psi and 100psi. I choose 100psi.
3) Plug the gauge half of the leakdown tester into the compressor and then turn the adjustment **** so that it reads 0Psi.
4) Remove the cover on the underhood fusebox. Should look like this.
5) Locate the 15A fuse in the upper lefthand corner and remove it. This prevents fuel from being squirted into the engine when manually cranking it over to TDC for each cylinder.
6) Proceed to the car and remove your valve cover.
Place all the bolts and valve cover gromets in a safe place. For me it's in the spark plug cover.
7) Then remove each spark plug like so.
Once all the spark plugs are removed, place them in a safe place.
This is also a good time to check them to see what condition there in.
8) Once each spark plug is removed, you then set cylinder 1 to TDC (Top Dead Center). You accomplish this by manually turning over the engine with the 19mm socket and extention on the rachet. Proceed to turn the engine counter-clockwise until your cam gears reach TDC for cylinder one.
9) Proceed to screw in the hose of the leakdown tester into cylinder 1
10) Attach the other half of the leakdown tester (gauge) to the hose in the spark plug hole, cylinder 1 and read the percentage of air that is leaking out of the cylinder.
1-10% leakage is normal. OEM Honda Specs. No engine is 100% leak free even when brand new. If the gauge reads above 10%. Listen to where the air is escaping from. The bigger the amount of leakage the harder it is to hear. Think of blowing thru a huge pipe with you mouth compared to a straw.
Air leakage Table:
Leaking out the exhaust = Exhaust Valve
Leaking into the intake/throttle plate = Intake Valve
Air bubbles in the top of the radiator(take off the rad cap) or into the adjacent cylinder = headgasket
Oil cap, Dipstick, Bottem end = Piston Rings
Remember that 1-10% is normal so you will still hear some air leaking out in general. Just more than 10% isn't normal or within Honda specs.
11) Repeat steps 8-10 for the remaining 3 cylinders and record them on a piece of paper.
12) Put everything back together. Install is the same as removal. Just follow the steps in reverse.
Good luck
Modified by wildoutwhitegsr at 9:45 AM 1/13/2006
Old Jan 12, 2006 | 01:11 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Re: ** How To - Leakdown Test ** (wildoutwhitegsr)
sweet nicely done
Old Jan 12, 2006 | 01:58 PM
BrooX's Avatar
Nice write up.
*saved to notepad*
Old Jan 12, 2006 | 02:20 PM
LoseRPunKx182's Avatar
Default Re: ** How To - Leakdown Test ** (DA9GUY-637)
saved to my computer!
Old Jan 12, 2006 | 02:32 PM
DC_RaceR's Avatar
Default Re: ** How To - Leakdown Test ** (LoseRPunKx182)
Very nice write.. But I can't seem to find the fuse on my block head?
Old Jan 12, 2006 | 02:42 PM
DoctorGSR's Avatar
whyd u even take the valve cover off?
Old Jan 12, 2006 | 03:42 PM
RE- v8killa121's Avatar
Default Re: (DoctorGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DoctorGSR &raquo;</TD></TR><TR><TD CLASS="quote">whyd u even take the valve cover off?</TD></TR></TABLE>
That's what i was thinkin...
why?
Old Jan 12, 2006 | 03:51 PM
ZipTieGUy's Avatar
Default Re: (RE- v8killa121)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RE- v8killa121 &raquo;</TD></TR><TR><TD CLASS="quote">
why?</TD></TR></TABLE>
to make it look more cooler, duh
Old Jan 12, 2006 | 03:55 PM
I know you don't have to, but for me personally I feel more confident in making sure I'm at TDC when looking at the cam gears instead of taking off the distributor cap and looking at the rotor.
Just a personally preference for me.
Old Jan 12, 2006 | 05:40 PM
CNSK's Avatar
nice write up..
Old Jan 12, 2006 | 08:34 PM
volcom40street's Avatar
Default Re: ** How To - Leakdown Test ** (CNSK)
Old Jul 28, 2009 | 05:59 PM
jonnybadboi9's Avatar
Yup, im with this guy as well when it comes to the valve cover...
Its A LOT EASIER with the valve cover off so you can look at the markings on the cam gears to make sure you are at TDC.
You turn the crank pulley.. which turns the belt... which turns the gears and you match up the markings to be at TDC for EACH cylinder when doing the Leak Down test.
Good writeup btw
Old Jul 29, 2009 | 04:55 AM
em1si's Avatar
i must be the only one who just puts a long 3/8" extension in the spark plug hole and rotates the crank till it i watch it hit TDC....i've been doin that for years...easier than takin off a VC or even takin ur dizzy apart..just my .02
Old Sep 7, 2010 | 01:19 PM
7rrivera7's Avatar
How do you guys keep the rotating assembly from moving when you apply air pressure?
sinister357
Aug 25, 2007 10:05 PM
1badteg
Jul 16, 2007 02:00 PM
integraRS-T
Jul 3, 2007 10:39 AM
rasinhell
Feb 22, 2005 11:06 PM
