***How-To Clean*** Your IACV a.k.a. Idle Air Control Valve
#151
Re: ***How-To Clean*** Your IACV a.k.a. Idle Air Control Valve
I've clean my iacv helped for 100 miles, clean it again nothing. Check voltage and found relay gave out. Bought a new one it didn't work. Checked all grounds wires and and power to the iacv all good. Well I installed my new iacv in my friends car(b18c) and it worked good, but not on mine still surges. So I bought another one and it worked for a little over 200 miles I just dont understand why they keep going out and not working on my engine(b18c) what else can relate to the iacv other than the fitv my engine came from an automatic sir-g from japan with really low miles or should I replace my fitv again, and yes I have had by pass it and it worked for about 1 hr. Someone that had a similar problem direct me to the right solution. And yes I've taken my car into the stealership...
#152
ok i did this and my car is sputtering still at like 1/4-1/2 throttle none before or after but at any rpm. is my iacv bad??
#153
#155
Re: (mouab18c1)
Get a can of throttle body cleaner from your local parts store and remove the hose that goes between the air filter and the throttle body. Have someone start the car and keep giving it gas or the engine will die. Spray at least half of the can of cleaner in the throttle body to clean the plate right inside. Also you will see a hole inside there spray cleaner into the hole also this hole allows the air to bypass the throttle plate and go to the idle control motor to keep your car idling at the rpm it is supposed to. If gunk gets built up in the idle control motor it will stick and cause the condition you described. Once the valve becomes unstuck it travels further than it should because the computer
is trying to get the engine air so it does not stall. Clean this all up like this and it should cure your problem.
#156
ima try this on my car.. my car actually idles low at times when im at a stop. its only sumtimes thoughh... about 100-200rpm ... any ideas? could doing this fix the problem? i already did a major tune up, spark plugs, cap and rotor, etc... any ideas would help. thanx
#158
ok so i did this today and when i first started my car it had a really hard time starting about 3 seconds to finally start up. then it idled around 2k then gradually went up to 3k?? is t his normal and now wen i put it to neutral to stand by my car rattles and drops kinda close to like around 5 close to the 0 rpm so when i put it to first it kinda rattles again. idk i think i just messed it all up
#159
Are you sure you followed the steps right? Check for any vacuum leaks and make sure you bleed the coolant.
#160
its all good now i guess it didnt dry up good enough after i let it sit a whole night it was good, now i just have to find a way to do the FITV how can i take that thing apart?
#161
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/
#162
ya it looks like it was gonna be easy but not really if you dont want to take the IM out. i wouldnt be able to take the third bolt out. i guess i should just get a shop do it
#165
is this accurate for a 04 honda accord 4 cylinder?? my car has been shaking on start up and i can't find any place for an accord iacv cleaning/repairing....
how much would shops usually charge for this procedure? i rather do it myself because i lack the funds and i don't know if it will solve the problem but i don't want my car to get worst.
help?
help?
#169
Reasons why you should take it apart and clean it:
-High idle after your car warms up
-Lumpy idle
-Roaming idle
-Hunting idle
-Fluctuating idle
my cars idle dips pretty low when i come to a stop, or when the ac is on..you think cleaning this would help? also do i neeed to bleed the cooling system after i do this, or could i jus top off the coolant?
-Lumpy idle
-Roaming idle
-Hunting idle
-Fluctuating idle
#170
Now your ready to re-install it back on the car so follow the steps backwards from 5 – 2
by removing iacv, coolant comes out..do i need to bleed cooling system?
#173
yea i have a problem my car wouldnt start up correct. like it would start but the idle would be real low then die. so i started it again and i revved it to stay up and it did but my idle kept jumping around so i keep it steady to rose my idle and when it reached a certain rpm it would just keep kicking back down. i had this problem before when i was driving so i had to pull over and towed it home and had the iac changed out and it worked. but im wondering if its just clogged with gunk but not sure cuz my engine light came on too. is this my problem or is it something else? if i cleaned it will my engline light turn off?
#174
Re: (wildoutwhitegsr)
Is there a FITV on 96 Civic DX? Or just IACV...
I had an integra LS (non-vtec) ecu that ran the engine fine, but threw like 4 different CEL codes and also made the rpm's wander sometimes.
NOW, I installed the sotck DX ecu p2e, and I only have ONE CEL, code 14 IACV.
took IACV off and cleaned it out, but it is still throwing the code.
The motor actually ran and idled somewhat normal with the integra LS ecu. But NOW when I start the car, it wont idle AT ALL, it IMMEDIATELY dies unless I give it gas.
If I give it gas, the rpm's fluctuate between 1500-2500 up and down like it is in limbo.
I AM able to rev past that, it's just pointless because the car dies when the rpm's drop back down..
d16y7 block
p24-5 head (?)
appears to be a y8 intake manifold, the throttle body is on the side instead of the usual DX vertical TB.
Help?
d16y7 block
p24-5 head (?)
Help?
