♠ Shaved, Tucked, Customized Engine Bays - Pics, Theory, Discussion ♠
Anyone using a Braille battery? I can get the 14115 model for $60 off a friend. Will this be enough?
147-B14115 Cranking Amp Tests:
PCA 5 seconds - 904 Amps
PCA 10 seconds - 791 Amps
PCA 20 seconds - 698 Amps
HCA 585 Amps
CA 486 Amps
CCA 360 Amps
Battery Usage Starting
Volts 12 V
Battery Terminals Top and side
Battery Type AGM
Cranking Amps at 0 Degrees F 360 amps
Cranking Amps at 32 Degrees F 486 amps
Length (in) 5.800 in.
Width (in) 3.400 in.
Height (in) 5.800 in.
Weight 11.500 lbs.
Quantity Sold individually.
* Lightweight, dual terminal design
* Brass auto terminals
* Solid top lead connections
* No spill, no corrosion, no maintenance
* Certified and fully charged
HCA 585 Amps
CA 486 Amps
CCA 360 Amps
Volts 12 V
Battery Type AGM
Weight 11.500 lbs.
Yeah I only drive the car in the spring summer months and a little into the fall and it gets parked after that. So it'll be 60 degrees plus anytime it's driven.
braille FTW .. just check the date on the bottom ..blake the owner of braille is a very good friend of mine . always takes care of customers .
im currently trying to score a litium battery off him
Ian
^^^ Anybody have the part # for where the throttle cable goes through the firewall on the EK? There are 2 wholes with notches right next to each other. Guessing one if for the throttle cable and the other is for cruse control cable? Not sure, but I can't find the plugs for them.
Don't think Honda has them. I just picked some up from a hardware store to use in various places.
habve a look here all listed in pic with part numbers
http://www.crxsi.com/jdm/ek9-1004248...m-Grommet1.htm
I met Blake way back in the day when he was driving around in a red hatch that was sponsored by sonny's BBQ. Good guy, and it's good to see he's come a long way.
Exactly why I went to the hardware store. They are 8 cents a pop and if you buy a few that don't fit you aren't out anything.
except 8 cents... :D This thread is massive and totally awesome, makes me want to wait and do my bay up before I swap.
You might want to think about getting a good quality float charger to store it on. It will help it last longer.
yep good ole sonny "yummy" lol !!!!! she got totaled was on a trailer headed up north and driver of tow van feel asleep . total van trailer and sonny
Hey have any of you guys used a motor mount bolt kit from hardware 909.I'm looking for a kit that has stainless bolts not just zinc plated steel.Any suggestions?
I know the zinc coating will hold up well when applied correctly but thats where I get worried most of the time cost wins over on quality.I am looking into the hardware 909 and the downstar kits but Hardware 909 never gets back to me so thats not a good thing,
