Vitara HALL OF FAME
Old Jun 10, 2010 | 07:41 AM
fjt's Avatar
fjt
Default Vitara HALL OF FAME
Well guys.
In order to create an informative thread for future Vitara piston build threads i decided to put together a "Hall of Fame" for those with Vitara piston built engines that have already Built, Dynoed and raced their setups.
This should help others to have an idea as to what to expect, what combinations other ppl are running and an estimate power figures depending on turbo used.
I hope this thread can be of big help and a good reference to be used...
Please post only results..this is not a "my build thread"
Please post the following info and ill start updating the list:
Dyno Plot:
Basic setup: (Block/Head)
Connecting rod used:
Size of turbo and PSI used:
What chassis
Track times: (if available)
I will make a Vitara Hall of Fame list by Power figures and by Track times
Thanks..
Old Jun 10, 2010 | 07:43 AM
fjt's Avatar
fjt
Default Re: Vitara HALL OF FAME
VITARA HALL OF FAME:
By Power:
1. JFK @ SpeedFactory ---------> 609whp & 404 lbs/ft.. Stock sleeves 75mm 30 PSI Presicion 6262 .. Z6/Y8 .. EG Hatch
2. SpeedFactory (Customer)---> 487whp & 376 lbs/ft.. Stock sleeves 75mm .. GT3076R 32-34PSI .. D16Z6 .. unknown chassis
3.TopmountGSR ----------------> 433whp & 325 lbs/ft(est.).. GT3076R 26PSI .. Unknown Chassis
4.xsenceo89x -------------------> 275whp & 245 lbs/ft (Est).. T3/t4 17PSI .. Y7/Y8head .. EJ8 Coupe
5. fjt -----------------------------> 266whp & 244lbs/ft .. T3 super 60 18PSI .. D16Y7 .. EK Hatch
BY TRACK TIMES:
1. JFK @ SPeedFactory ---> 10.48 @ 139mph (with 471whp)
2. TopmountGSR ---------> 11.2 @ 128
3.fjt ---------------------> 12.4 @ 111
4. xsenceo89x -----------> 12.4 @ 110
Old Jun 10, 2010 | 01:04 PM
fjt's Avatar
fjt
come on guys... i know there are plenty of built vitara setups out there...
Help me build a good database for those who will boost in the future..
Old Jun 10, 2010 | 07:43 PM
Slow_boost's Avatar
Right now im at 220hp/198tq w my vitaras on a gt25r. Will update when i put my new setup on if i decide to keep my vitaras instead of going w wiseco. The low comp is killing my power and drivability.
Old Jun 11, 2010 | 01:39 AM
Sohc52's Avatar
By Power:
4.SOHC52-------------------> 309whp & 285 lbs/ft (Est).. Stock sleeves 75.5mm T3/t4 trim 60 21PSI .. Z6 .. EG 4DR
5.xsenceo89x -------------------> 275whp & 245 lbs/ft (Est).. T3/t4 17PSI .. Y7/Y8head .. EJ8 Coupe
BY TRACK TIMES:
Old Jun 11, 2010 | 05:34 AM
kit88's Avatar
My best time 11.07 at 118 mph (letting off the gas)
d16a6/z6 head
75.5 mm vitaras
3.6 Bisi cam
Go-Autoworjs spec turbo by Bulsseye (17psi)
1000cc injectors
Soon new tune at 25 psi and dyno graph
Old Jun 11, 2010 | 02:19 PM
TylerB's Avatar
Dyno Plot: 280whp/240wtq - Tuned by BRMS
Basic setup: d16z6, Walbro 255, Precision 650cc, YCP 75.5mm, Stock head, Stock IM, Stock TB
Connecting rod used: Fj Custom Length
Size of turbo and PSI used: t3/t04e, 14psi
What chassis: 92 cx Hatchback
Old Jun 11, 2010 | 02:30 PM
fjt's Avatar
fjt
guys i need the dyno sheets if possible..
Thanks..
Want to avoid any BS flags from others on power figures so proof is greatly appreciated.
If you dont have where to host it send it to me and ill upload them..
Thanks
Old Jun 11, 2010 | 02:33 PM
fjt's Avatar
fjt
What engine?
Dont change pistons... change to the custom length rods...
Wisecos compression for D series is around 8.5:1
Its cheaper to switch to the custom length rods for the vitara pistons than to buy new wisecos....
Old Jun 11, 2010 | 02:37 PM
TylerB's Avatar
Only graph I have, timing was pulled out after this run to get the extra 10hp I stated.
Old Jun 11, 2010 | 09:46 PM
JFK78's Avatar
Can you also put the weight down next to the time so that people have a better idea of what to expect at given power/weight ratios?
I was at 2300lbs on my setup.
Please add to the list:
Dr. D-series went quicker than me last year. I believe he has the quickest ET on a Vitara build.
Vitara Z6, 75mm
436 whp 340 tq
10.45 @132mph
Weight: ~2000lbs.
Old Jun 12, 2010 | 07:06 AM
turbo sol's Avatar
BASIC SETUP; >
Z6 head / block
skunk2 intake
zex cam
z6 transmission
RODS AND PISTONS; >
eagle rods
75.5 vitara pistons
TURBO AND PSI; >
garret t3 .42/.63
http://www.go-autoworks-store.com/gat3su60.html
250 hp @ 14.5 psi
2.5 downpipe
spoolin performance log manifold
CAR BODY; >
96 CX
TRACK TIMES; >
none
DYNO NUMBERS; >
250hp @ 15psi
http://www.youtube.com/watch?v=Q2F3T9hhOM0
Old Jun 30, 2010 | 06:35 PM
JDM_SOHC's Avatar
Just got my 75.5's hope to be in this crowd soon..!! It's kinda shitty when searching for build info on these, everything is so sporadic.. I wish there was a baseline FAQ database to let us know what works and what doesn't... Even on TurboD16 it seems like everyone's just kinda asking everyone else questions and ****... Oh well I hope mine comes out legit haha..
Old Jun 30, 2010 | 07:54 PM
Garage 808 Hatch's Avatar
Garage 808 hatch. D16Y7 block and head. stock bore vitaras with chinese H beams. 2700lb ek hatch 347/274 on 92 oct best of 11.54 @ 118mph
best pass is slip on left, right lane, other 2 runs were on the brakes
this was on our dyno jet. went to a dyno day and turned it up a hair and made the 347
Old Jun 30, 2010 | 09:03 PM
Got traction's Avatar
James @ SF just broke a couple records:
635whp/421tq @ 38psi
http://www.youtube.com/watch?v=7_tQu5SOl8s
Old Jul 1, 2010 | 11:29 AM
ReDemoN's Avatar
DixielandImports Please
HAHAHA u could say that again
Old Jul 5, 2010 | 07:12 PM
Fr0z3N's Avatar
400.3whp 335tq
z6 block vitara/fj rods. stock head
94 octane pump gas
borgs warner s256 turbo
about 25 psi iirc with boost cut at 31psi
92 eg hatch
I have a dyno chart if you wanna pm me your email I can send it
ran 12.0 at 12psi 260whp never made it to the track at 400whp
Old Jul 6, 2010 | 08:58 AM
extralargenog's Avatar
James tuned Nolans car to like 489 and ridiculous TQ on a 30 R on Pump and meth.
Old Jul 26, 2010 | 05:53 AM
Foowee's Avatar
Here's my setup... So far it's done a best of 12.1@112 on 14lbs.
d16a6
Decked .075
Milled .016(I had to shorten the dowel pins and oil control jet)
aerospeed adj. cam gear
z6 intake manny
62mm tb
std. bore techline coated ycp vitaras
devcon filled
eagle rods(137mm)
drilled mains
techline coated stock valves(Panda-hatch sprayed my coatings)
std manifold
bmc t3 adapter plate
t3/t04e 57trim .63ar ex
xs power 24x12x4 fmic
38mm china wg
L3 si tranny w/dx final and an obx(Mista Bone nuff said)
exedy 3 puck
walbro 255 hp with 8 guage wiring
fic p&h 550's
motorolla 2.5bar
te2.62 ng60(thanks xeno n splitime)
innovate lm1
tt coolant adapter
I'm in the middle of a chassis swap and am making some improvements along the way... The new car had a K-series in it. So I'm undoing all that mess.
Once it's all back together I'm going for 11's...
Also, the ycp's in my motor are installed with the arrows pointing at the timing belt. I now know this is the incorrect way to install them. However, they still work...
http://vimeo.com/2033458
Mach1n1st
Dec 1, 2012 10:32 PM
young noob
Aug 25, 2007 07:09 AM
CRX MASE
Aug 16, 2007 04:28 PM
type B16
Aug 25, 2006 09:01 AM
lube
Nov 16, 2004 05:01 PM
