code 4 crankshaft position sensor need help fast
Old Jul 22, 2009 | 05:15 PM
KDvtec5757's Avatar
Default code 4 crankshaft position sensor need help fast
hey guys i have a JDM b16a and ecu is saying code4 i no its crankshaft position sensor i just dont no what to do to fix it and would that make cut out at 3000rpms
Old Jul 22, 2009 | 07:27 PM
D16SiHatch's Avatar
Default Re: code 4 crankshaft position sensor need help fast
dizzy probably took a crap on ya
Old Jul 23, 2009 | 03:53 AM
KDvtec5757's Avatar
no it good i guess i am just going to get a nes crank position sensor so its a jdm b16a what car can i get one for that will work
Old Jul 23, 2009 | 04:08 AM
.Manny.'s Avatar
Touching My Member
its inside the distributor. is the timing belt on correctly?
Old Jul 23, 2009 | 04:43 AM
dephtone's Avatar
You have to buy a whole new distributor assembly to replace the crankshaft position sensor.
Here is the Factory Service Manual to see what the issue is.
The pics are kinda small, if you can't read them let me know, I will send you the PDF file for the troubleshooting.
Old Jul 23, 2009 | 01:30 PM
KDvtec5757's Avatar
no i cant read them thanks a lot guys if i would get a new dizzy tho would that work better and so guy told me that it was down by the water pump thats were the crank sensor was
Old Jul 23, 2009 | 01:35 PM
KDvtec5757's Avatar
hey a nother thing i just did the swap and its a dx so i had to re wire the dizzy plug on and all that with the pin for b10 b12 and to other pins i think it was 2 c pins
Old Jul 23, 2009 | 01:40 PM
jlicrx's Avatar
that guy doesn't know what he is talking about - on OBD2 engines, there is a sensor behind the crank pulley, however, it is not the CKP (Crank Position Sensor) but is the CKF (Crankshaft Speed Fluctuation Sensor) and is only read by OBD2 ECUs - you have a CKP problem and the sensor is in the distributor - probably not the sensor that is bad - more likely, the bearings for the distributor shaft are worn allowing the shaft to move laterally and causing the sensor to, in effect, short out - best get a different distributor - very common problem on B-series engines - most people that i know with a B16A carry a spare distributor since they are constantly going out
Old Jul 23, 2009 | 01:42 PM
jlicrx's Avatar
you could try switching the orange and white CKP sensor wires at the distributor connector and see if that fixes it
Old Jul 23, 2009 | 04:21 PM
D16SiHatch's Avatar
good advice ^
op: now that you made us aware you did a dpfi to mpfi conversion it seems quite possible that you simply reversed these wires. double check the wiring and make sure its going to the right spot on the ecu. if that's not the problem then the next step would be to replace the dizzy because the CKP is inside it.
Old Jul 23, 2009 | 06:07 PM
KDvtec5757's Avatar
thanks guys i got to looking and i forgot to sauder the one wire and it was not on good but all good now thanks a lot for the help guys
hondaclown
Jul 17, 2023 08:14 AM
pos94accord
Jan 25, 2009 05:29 PM
Shikaido2004
Jul 31, 2008 08:50 AM
Topdawgg
10
May 7, 2006 04:00 PM
YellowR2000x2
Mar 4, 2005 04:29 PM
