radio just shut off... anti theft light is blinking
Old 09-22-2004, 11:12 AM
96AccordEX's Avatar
Default radio just shut off... anti theft light is blinking
Hey while i was driving the other day my radio just shut off, the next day my car died so i took it to the dealer and he put in a new alternator... but the radio still wont come on.
What can the problem be? Is there more to it to get the radio back on?? And if i replace the factory radio with my cd deck will it work??
Old 09-22-2004, 11:21 AM
fleetmack's Avatar
Default Re: radio just shut off... anti theft light is blinking (96AccordEX)
you probably blew the radio's fuse
Old 09-22-2004, 11:25 AM
96AccordEX's Avatar
Default Re: radio just shut off... anti theft light is blinking (fleetmack)
so check the fuse box under the hood or is it under the steering wheel?
Old 09-22-2004, 11:29 AM
fleetmack's Avatar
i don't have my manual with me - and i have a 95lx - but i'm pretty sure if i remember right it's under the hood. there should be a sheet on the one under your hood telling you what each fuse # does....if it ain't there it's just to the left of your left foot when you're driving (if it's the same as a 95)
Old 09-22-2004, 12:31 PM
96AccordEX's Avatar
well i checked under the hood and the diagram said 7.5 Radio (backup) and 2 spaces above was just a regular 7.5 fuse... i tried swapping them radio still doesnt work... and when i went into the car my clock was reset. Im going to go and buy fuses... but if i go ahead and install my cd player do u think it will work???
Old 09-22-2004, 02:26 PM
aZnAcCoRd02's Avatar
Replacing the alternator is like takin all your power away. Try the radio code im pretty sure thats what happened. If you install a cd player you should be straight. If the anti-theft light is on there is power going to the unite
For safe measures:
1. Take off positive battery cable for 2-3 mins
2. Reconnect
3. Turn on car and enter radio code given to you
Old 09-22-2004, 03:16 PM
96AccordEX's Avatar
Default Re: radio just shut off... anti theft light is blinking (aZnAcCoRd02)
i got it to work, there were 2 fuses blown a 7.5 and a 15 which was for the radio, i also installed the cd deck.... another question:
Do i need a mounting kit? or can i use what it came with??
Old 09-23-2004, 06:47 AM
Heat's Avatar
The easiest way to tell if you would need a kit would be to go to http://www.crutchfield.com , pick out a radio of the same size as what you have, put it in your cart and see if they automatically add a kit.
If they add a harness but no kit, you don't need a kit. If they do add a kit, then you probably need one. If you need one, just check out any local stereo installer, they'll sell you a metro kit for ~ $12 or $15. For the harness, look at some place like Wal-mart, you should be able to pick one up for ~ $7 or so (or you could buy the harness from the stereo install place for ~ $12 or $15).
Old 09-26-2004, 05:33 PM
SYTFU Tommy.'s Avatar
where is the 15 located at? having same problem. wats the name for the 15 btw like wat is it for
Old 09-27-2004, 05:04 PM
Default Re: radio just shut off... anti theft light is blinking (tngay)
bumps
Old 09-27-2004, 06:59 PM
ichibanjap's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96AccordEX &raquo;</TD></TR><TR><TD CLASS="quote">i got it to work, there were 2 fuses blown a 7.5 and a 15 which was for the radio, i also installed the cd deck.... another question:
Do i need a mounting kit? or can i use what it came with??</TD></TR></TABLE>
You can get a dash kit, or with a little work you can use the factory pocket. Using the factory pocket looks better, but it isn't fun making sure it stays and looks perfect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tngay &raquo;</TD></TR><TR><TD CLASS="quote">where is the 15 located at? having same problem. wats the name for the 15 btw like wat is it for</TD></TR></TABLE>
Check in the driver side kick panel.
Old 09-27-2004, 09:08 PM
Default Re: radio just shut off... anti theft light is blinking (ichibanjap)
there is a lot of 15 if u no wat i mean. need to know which one i should check. TIA
Old 09-28-2004, 02:57 AM
96AccordEX's Avatar
its in the row where the 2 7.5s are... i believe it says radio, ciggerate lighter, and something else
Old 09-28-2004, 04:42 AM
Hondaman56's Avatar
Location: Filthadelphia City of Brothers and Love, PA, USA
Old 09-28-2004, 05:36 PM
changed that, still doesnt work. neother help?
tacpsi
09-23-2019 06:20 PM
Kenneth.Honda94
Audio / Security / Video
09-16-2014 10:04 AM
ProjectCD5
03-19-2009 08:12 AM
92redhatch
02-06-2006 08:52 AM
CompanyFlow
11-24-2004 08:04 PM
Quick Reply: radio just shut off... anti theft light is blinking
