Different between D16Z6 and D16Z7 (Civic 5gen.)
Hi i have a question What is the different between this two engines in civic 5gen. 92-95 D16Z6 and D16Z7 .I search but i can find.Please help me.Thanks
Re: Different between D16Z6 and D16Z7 (Redline130)
Yes it is i have one in my civic and he look the same like D16Z6 but i don`t know what is the different or maybe there are no different .
Well then you have a swap. The z7 comes in 96-00 civic Ex's. Rated at 127 hp, and 107 ft lbs of torque. U gain 2 hp over the z6 and 1ft lb. the comp on the z7 is also .5 a point higher than the z6, so its got a 9.7:1 comp ratio.
Re: (phatrick2332)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatrick2332 »</TD></TR><TR><TD CLASS="quote">Well then you have a swap. The z7 comes in 96-00 civic Ex's. Rated at 127 hp, and 107 ft lbs of torque. U gain 2 hp over the z6 and 1ft lb. the comp on the z7 is also .5 a point higher than the z6, so its got a 9.7:1 comp ratio.</TD></TR></TABLE>
I thought 96-00 civic ex's had the D16Y7 or Y8 not Z7
Never heard of this Z7 before.
1 Post
Re: Different between D16Z6 and D16Z7 (aamadeus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aamadeus »</TD></TR><TR><TD CLASS="quote">But i have this engine in my civic 1992 5gen. </TD></TR></TABLE>
Where do you live.. sounds like a EDM motor.
Re: (QUiKSR20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QUiKSR20 »</TD></TR><TR><TD CLASS="quote">
Never heard of this Z7 before.</TD></TR></TABLE>
That's what I thought, unless like it was stated that this is an EDM motor.
Re: (phatrick2332)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatrick2332 »</TD></TR><TR><TD CLASS="quote">I guess im the only one that noticed hes in poland lol... Yes, usdm 96-00 ex's had the y7. EDM,s z7</TD></TR></TABLE>
no the usdm 96-00 ex had d16y8's
Re: Different between D16Z6 and D16Z7 (Civic 5gen.)
So by swapping these two engines the only difference is "Performance"...
Should I worry about the computer???
And what about the timming????
Are they the Same????
D16z6 - D16z7
D16z6 - D16z7
