THE ULTIMATE DIY AFTERMARKET TACH INSTALLATION
Old 08-05-2004, 03:22 PM
Honda-Tech Platinum Member
Setsuna F Seiei's Avatar
Default THE ULTIMATE DIY AFTERMARKET TACH INSTALLATION
INTRODUCTION:
I've been seeing a lot of threads regarding people asking of immediate help on their aftermarket tachometer installations. This guide will hopefully end all questions as far as the electrical wiring is concerned. I SUGGEST YOU READ EVERYTHING BEFORE PROCEEDING FURTHER DOWN THE INSTALLATION SECTION!
DISCLAIMER:
I am NOT liable for the damages or injuries that you sustained for this installation guide. Proceed at your own risk! Click here for failure to comply. All pictures are taken off different websites since I don't have a camera to take my own. I will immediately take them down if needed just e-mail me at pnoyvillageidiot@yahoo.com
APPLICATIONS:
Most Honda vehicles.
MATERIALS:
1. Heat shrink tubings-
Needed to cover up soldered wires that were tapped into. I prefer multi-color for a much cleaner and invisible look but you can use regular heat shrink tubings that matches the right gauge of your wires.
Multi-color heat shrink tubings can be picked up from your local Radio Shack.
2. Wire cutter-
Needed to cut through thick and thin gauge wires.
Kronus™ 4.5" mini diagonal cutter from Radio Shack.
3. Wire stripper-
Needed to strip different gauge wires.
Kronus™ 4-way crimping and stripping tool from Radio Shack.
4. Solder iron and clear flux solder or solderless connectors/crimp connectors-
Needed to securely connect the wires needed to be tapped into and wires coming from your tachometer. If you don't have soldering irons or don't want to buy one,
you can always use crimp connectors but I'd rather recommend soldering since they provide the best reliability under 13G launches at the drag strip . Crimp connectors tend to become loose over time and eventually disconnect the wires.
Dual-wattage iron from Radio Shack.
5. Dental pick or any other sharp tool to separate wires when tapping.
6. Screw driver, screws, and other items needed for mounting your tachometer.
7. Last but not the least, your aftermarket tachometer!
Most people have Autometer/Autogauge aftermarket tachometers but I decided to pick up one of Defi's Step Graph tachometer with a control module since I like the small and stealthy look (3 1/8") compare to most of autometer's tachometers at 5." I got it brand new for $279.99 plus shipping on overboost.com.
INSTALLATION:
1. Since most people have an Autometer tachometer, I decided to use Overboost's installation pictures of an Autometer tachometer on their project CRX and Civic.
Before we proceed, here's a basic wiring diagram provided by Autometer for most applications-
For more questions regarding the wiring diagram, go here
http://hp.autometer.com/techti....html
Here's a wiring diagram from Defi-
The wire colors for different tachometers vary depending on the manufacturer. As you can see from the above diagrams, the some wiring colors and connections are different esp. on the RPM signal wire connection. Despite of different wire colors, they serve the same purposes and are tapped into the same destination wires.
Again since most people use Autometer's tachometer's and the only pictures I have are that of Overboost's using it then I will show you installation using Autometer's wiring diagram.
2. Take all necessary materials out. Make sure you don;t leave your keys in the ignition and disconnect negative cable off the battery for safety measures lol.
3. Decide on a mounting location of your tachometer (Most people prefer mounting it to the A-pillar since it provides a more stable seating of the tachometer and you can use it to hide the wires behind it. Also, where I'm from the overzealous drag strip inspectors would give your tachometer a yank to check if it would shake violently during the race.)
4. Install the tachometer stand.
If you have one of those removeable A-pillar covers, use the following pictures-
Full images-
http://overboost.com/pix.asp?i...4.jpg
http://overboost.com/pix.asp?i...5.jpg
http://overboost.com/pix.asp?i...7.jpg
If you don't have a removeable A-pillar cover or don't have one at all (old model Hondas)-
Full images-
http://overboost.com/picture.a...5.JPG
http://overboost.com/picture.a...6.JPG
http://overboost.com/picture.a...7.JPG
5. Remove the dash or do whatever you need for all I care to get access on the wires that are to be tapped into. https://honda-tech.com/zerothread?id=636033
6. IF YOU DONT KNOW HOW TO SOLDER GO HERE http://www.mmxpress.com/technical/connections.htm
Luckily most Hondas are pre-wired for tachometer connections. Green wire on Autometer tachometers goes to a blue wire coming off the backside of instrument cluster or THERE'S A DEAD END SINGLE WIRE (BLUE) HARNESS UNDER THE HOOD BY THE STRUT TOWER NEAR THE MC-
Full image-
Black wires goes to a good ground-
Full image-
Red power wire goes to the yellow ignition switch-
Full image-
http://overboost.com/picture.a...0.JPG
The remaining white wire feeds off power and light and can be spliced into any bulb wires in the dash. ***ALSO YOU CAN CONNECT MOST OF THE WIRES COMING OFF THE TACHOMETER BY STICKING THEM AROUND FUSES IN THE UNDERDASH FUSEBOX SIMPLY BY WRAPPING THEM TO THE RIGHT FUSES OR USING FUSE TAPPERS OR USING SPADE CONNECTORS AND STICK THEM IN THE TERMINALS WITH NO FUSES. Use a test light or a voltmeter to check which ones are your constant and power wires
7. Now that you're done with wiring, check to see if everything is working, set your tach at preferred RPM, reconnect negative battery cable, replace A-pillar cover (if taken off) and VOILA! Enjoy your new tachometer hahaha.
PROPS:
Thanks to the following-
1. Overboost http://www.overboost.com
2. MMXpress http://www.mmxpress.com/technical/connections.htm
3. Radio Shack http://www.radioshack.com
4. Defi http://www.defi-shop.com
5. Autometer http://www.autometer.com
6. H-T member Smith Wise for EK dash removal write-up
FOR MORE QUESTIONS REGARDING THE INSTALLATION, EMAIL ME AT pnoyvillageidiot@yahoo.com AND FEEL FREE TO POST MORE INFORMATION TO THIS THREAD IF NEEDED
Modified by BrokeAssPinoy at 6:33 PM 8/5/2004
Modified by BrokeAssPinoy at 6:40 PM 8/5/2004
Modified by BrokeAssPinoy at 8:57 PM 8/5/2004
Modified by BrokeAssPinoy at 9:00 PM 8/5/2004
Modified by BrokeAssPinoy at 5:11 PM 1/2/2005
Modified by BrokeAssPinoy at 10:20 PM 5/29/2005
Setsuna F Seiei is online now
Old 08-05-2004, 03:26 PM
Risky Business
BauleyCivic's Avatar
Default Re: THE ULTIMATE DIY AFTERMARKET TACH INSTALLATION (BrokeAssPinoy)
fix your pictures sir
BauleyCivic is offline
oops some images are not working. I'm fixing them right now. BE PATIENT!
Old 08-05-2004, 03:34 PM
Pictures are back up!
Old 08-05-2004, 03:47 PM
MNEJ1GUY's Avatar
MNEJ1GUY is offline
Old 08-05-2004, 03:49 PM
SiYouLater's Avatar
cool, post it here https://honda-tech.com/zerothread?id=642479
SiYouLater is offline
Old 08-05-2004, 03:57 PM
vtec69's Avatar
Default Re: THE ULTIMATE DIY AFTERMARKET TACH INSTALLATION (BauleyCivic)
good write up
vtec69 is offline
Old 08-05-2004, 04:06 PM
G U E C O's Avatar
Default Re: THE ULTIMATE DIY AFTERMARKET TACH INSTALLATION (vtec69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec69 &raquo;</TD></TR><TR><TD CLASS="quote">good write up </TD></TR></TABLE>
G U E C O is offline
Old 04-12-2005, 09:14 AM
Mooneyes13's Avatar
Default Re: THE ULTIMATE DIY AFTERMARKET TACH INSTALLATION (stock93cx)
Mooneyes13 is offline
Old 04-14-2005, 07:43 PM
Rpizzle's Avatar
or you can spend about 30 bucks, and take it to a shop
Rpizzle is offline
Old 04-14-2005, 08:00 PM
vtec y0's Avatar
Default Re: THE ULTIMATE DIY AFTERMARKET TACH INSTALLATION (Rpizzle)
nice write up
vtec y0 is offline
Old 04-14-2005, 08:32 PM
I am a (Trial User) Army
litterbox's Avatar
Default Re: THE ULTIMATE DIY AFTERMARKET TACH INSTALLATION (vtec y0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rpizzle &raquo;</TD></TR><TR><TD CLASS="quote">or you can spend about 30 bucks, and take it to a shop</TD></TR></TABLE>Douche.
Very detailed writeup.
litterbox is offline
Old 04-14-2005, 09:32 PM
Electrician
Deemeetree's Avatar
******* tool.
All that isn't necessary though. Every wire can be tapped to the cluster harness and the RPM lead to the harness right in front of the driver firewall.
Deemeetree is offline
Old 04-15-2005, 05:40 PM
litterbox's Avatar
Default Re: THE ULTIMATE DIY AFTERMARKET TACH INSTALLATION (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">******* tool.</TD></TR></TABLE>haha
Bump for some good info.
Old 04-15-2005, 06:41 PM
As long as I dont have to take out any more Metal Gears
rukawa1one's Avatar
thanks for this DIY, I'm going to need to do this really soon after i get a swap
rukawa1one is offline
Old 04-15-2005, 06:45 PM
ExiledinIN's Avatar
Default Re: THE ULTIMATE DIY AFTERMARKET TACH INSTALLATION (rukawa1one)
I've seen the autometer in dash tachs. Has anyone replaced the speedo and tach w/ the autometer in dash ones?
ExiledinIN is offline
Old 04-15-2005, 07:28 PM
stormy's Avatar
Default Re: THE ULTIMATE DIY AFTERMARKET TACH INSTALLATION (ExiledinIN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExiledinIN &raquo;</TD></TR><TR><TD CLASS="quote">I've seen the autometer in dash tachs. Has anyone replaced the speedo and tach w/ the autometer in dash ones? </TD></TR></TABLE>
it disables several things that are federally prohibited. I've done it and to get gauges big enough to be usefull it looks ***
stormy is offline
Old 04-15-2005, 09:04 PM
tur3oDC4's Avatar
good idea, thats an option for those of us without *****'s
tur3oDC4 is offline
Old 12-28-2005, 10:25 PM
gtgoku's Avatar
Default Re: THE ULTIMATE DIY AFTERMARKET TACH INSTALLATION (tur3oDC4)
ok got my tach all connected and stuff... a friend of mine gave me this... i think its a shift light... how the hell do I connect it? it comes with 2 black wires none of them say positive nor negative... where the hell im i suppost to plug in this crap...=D
thanks
gtgoku is offline
Old 12-28-2005, 10:29 PM
HT Order of Merit
JDM_Ej's Avatar
Default Re: THE ULTIMATE DIY AFTERMARKET TACH INSTALLATION (gtgoku)
It is a shift light. It should connect to the tach itself. If not, your going to need a RPM "pill" to signal it to go off.
JDM_Ej is offline
Old 12-28-2005, 11:09 PM
revvin9k's Avatar
ROFL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tur3oDC4 &raquo;</TD></TR><TR><TD CLASS="quote">good idea, thats an option for those of us without *****'s </TD></TR></TABLE>
revvin9k is offline
Old 12-29-2005, 12:01 AM
eeeKs's Avatar
good write up
eeeKs is offline
Old 12-29-2005, 08:01 AM
gtgoku's Avatar
Default Re: THE ULTIMATE DIY AFTERMARKET TACH INSTALLATION (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">It is a shift light. It should connect to the tach itself. If not, your going to need a RPM "pill" to signal it to go off.</TD></TR></TABLE>
very interesting... but my tach doesnt have any place to connect the damn 2 wires... do you think I have to tap it to any of the four color wires? or would i have to o pen the tach and solder them inside somewhere? has someone done this or has come acros this?
gtgoku is offline
Old 08-15-2006, 08:03 PM
Jhonny Ricer's Avatar
So I know this is bringing back a dead thread but a little helpful info. If you want too and are able too you can go directly to the cluster for all power, ground, illumination, and tach for your tachometer to work in most tegs and civics...
https://honda-tech.com/zerothread?id=1053318
This post will tell you which pin to look for as well as what color wires do what on your cluster harness for MOST Honda civics and tegs. Helpful and a little easier than running wires all over the place and works like a charm I had it done in less than five minutes of removing all trim and the cluster.
Jhonny Ricer is offline
Old 08-15-2006, 08:58 PM
Syndacate's Avatar
Nice.
I'd just fix it so you don't have to have a login/password to enlarge the pictures.
Syndacate is offline
Quick Reply: THE ULTIMATE DIY AFTERMARKET TACH INSTALLATION
