92 prelude check engine light on
Old 07-25-2004, 05:31 PM
1fastvw's Avatar
Default 92 prelude check engine light on
what do you got to do to get the code out of this computer. Im use to working on vw and audis and I cant find the dlc. Any help would be great. It comes on first thing in the morning and wont idle well. by the time I get top work its off and runs fine.
Old 07-25-2004, 06:00 PM
delguiner's Avatar
Default Re: 92 prelude check engine light on (1fastvw)
allright man, easy as pie... get under the dash in your car (drivers side), and look to the right of the brake pedal, right behine the plastic middle there should be a connector there with a blue and brown wire connected into it. Now take a pin and jump both sides of the connector and put your key in the on position. Your check engine light will flash you codes
Hope this helps u out,
Joey
Old 07-25-2004, 08:43 PM
darylfiend11's Avatar
http://www.92lude.com/diagnose_error_codes.htm
That site has a write up on how to do it and has a list of the codes
Old 07-26-2004, 11:52 AM
vtecpreludude's Avatar
Default Re: 92 prelude check engine light on (delguiner)
would this also work for a 96 prelude? i've got a CEL too
Old 07-26-2004, 11:57 AM
delguiner's Avatar
Default Re: 92 prelude check engine light on (vtecpreludude)
i thgink its valid on all 4th gen preludes... give it a try you dont really have much to lose!
93LUDEH22SWP
03-26-2008 01:31 PM
royalfelix
11-07-2007 01:05 PM
royalfelix
08-05-2007 04:57 PM
bobbysunshine
02-02-2006 03:54 AM
Clydsdal
09-21-2003 08:15 AM
Quick Reply: 92 prelude check engine light on
