can you replace the sunroof seal on a 6th gen civic?
Old 07-10-2004, 02:44 AM
brooksto's Avatar
Default can you replace the sunroof seal on a 6th gen civic?
My sunroof seal is looking really bad, I dont think it is leaking yet but it probably will soon. I checked over at majestic honda and from the parts diagrams, it appears that you have to buy a whole new glass panel because the seal is permanently attached. Is this true or is there a way to replace the seal without having to buy a whole new sunroof?
Old 07-10-2004, 07:51 AM
Matty.'s Avatar
Default Re: can you replace the sunroof seal on a 6th gen civic? (brooksto)
bump cuz I would also like to know.
Old 07-17-2004, 01:16 AM
brooksto's Avatar
Default Re: can you replace the sunroof seal on a 6th gen civic? (gumtape_deathmatch)
bump
Old 07-17-2004, 03:22 AM
INVALID's Avatar
Location: Why so you can pretend like youre interested, FL/OK
If you don't find the answer you're in search for, I would suggest either calling Honda directly or another company that carries Honda parts to find out what options you have in replacing this as cost effectively as possible
Old 07-18-2004, 02:53 PM
vtecpower1062's Avatar
Well the seal part number is 70080-S01-A01 and runs $25.45 on http://www.slhondaparts.com . As for replacing the seal, I would honestly recommend the helms manual for replacing the seal. Makes things alot easier using it.
Old 08-05-2004, 12:39 AM
brooksto's Avatar
Default Re: can you replace the sunroof seal on a 6th gen civic? (vtecpower1062)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecpower1062 &raquo;</TD></TR><TR><TD CLASS="quote">Well the seal part number is 70080-S01-A01</TD></TR></TABLE>
That is the part number for the frame seal that is inside the roof panel, I want the seal that goes around the glass sunroof panel that you see from the outside when the sunroof is closed, as far as I can tell, you have to buy the whole sunroof/glass combo at $265. There's got to be a better way.
Old 08-05-2004, 01:14 AM
99CivicExCoupe's Avatar
bump i'd like to know too, my ex sunroof has that plastic and for some reason one part always sticks up...i dont want it to leak, anyone else with info would be greatly appreciated
Old 08-22-2004, 07:01 PM
brooksto's Avatar
Default Re: can you replace the sunroof seal on a 6th gen civic? (99CivicExCoupe)
bump
Old 09-21-2004, 12:42 AM
brooksto's Avatar
bump
Old 09-21-2004, 12:59 AM
VTECMaster's Avatar
yeah ****** weazel tore mine apart!!!
bump please help!
Old 09-21-2004, 04:55 AM
CivicEX96's Avatar
Default Re: can you replace the sunroof seal on a 6th gen civic? (VTECMaster)
mine is slowly starting to leak too, seems like a very common problem with age
Old 01-30-2005, 11:08 PM
brooksto's Avatar
Default Re: can you replace the sunroof seal on a 6th gen civic? (CivicEX96)
bump
Old 01-30-2005, 11:38 PM
dantastic's Avatar
fyi, the sun roof seal doesn't seal out water perfectly. that's why there are drains for the area around your sunroof. sunroof leaks are usually caused by plugged up drains
Berick920
01-29-2014 06:44 PM
zhunterzz
08-06-2013 07:42 PM
moonakis
Honda Civic (2001 - 2005)
10-03-2009 03:21 PM
Tazragoon
10-20-2006 09:04 AM
realblag
10-07-2003 04:46 PM
Quick Reply: can you replace the sunroof seal on a 6th gen civic?
