| Welcome to Honda-Tech! | ||
#1 |
Help installing a turbo timer and i need help from anyone who knoes the wire colors .... does anyone have a diagram of the igntion switch? i need to knoe which is which........ ACC ON IGN1 IGN2 12v ...... and can you confirm what the purple wire connects too? is it SPEEDOMETER OR RPM?
did search but did not find one for ef models ASAP |
#2 |
bat-a(12v.) from fuse box=wht/blk
ign1 = blk/yel ign2-a = yel ing2-b = blu/wht acc = wht/red start = blk/wht key on should be ign1. i think you mean blue and not purple, cause there is no purple wires. it should be blue for rpm |
#3 |
thanks for the quick response...... the purple i was referring to from the turbo timer..... does it hook to the rpm or speedo?
#4 |
What does the instructions tell you to hook it to?
All of my posts should be considered for being made into a sticky. |
| Tags |
| 1990, 90, civic, code, codes, color, crx, harness, honda, hondatech, ign1, ign2, ignition, mean, switch, wire |
