Metric Left Hand Thread Nuts (reverse thread)
Old 05-19-2004, 06:34 PM
oMek's Avatar
Default Metric Left Hand Thread Nuts (reverse thread)
i just got some aftermarket heim endlinks in today. they are missing the nut between the joints that will allow you to lock it down so they dont swivel
they are m10 X 1.50, one side is reverse threaded and i cant find a bolt to fit it anywhere.
anyone know where i can get 1?
Old 05-19-2004, 07:17 PM
oMek's Avatar
Default Re: Metric Left Hand Thread Nuts (oMekoneDC2)
anyone?
Old 05-19-2004, 07:23 PM
Will you make something up for me please?
shamoo's Avatar
Do you have a Lowes home improvement store where you are? It's similar to a Home Depot, but a little newer.
The Lowes near me have a very large selection of metric bolts/nuts. Much more than Home Depot which has like 10 total. I remember going to Lowes for many replacement Honda bolts that I lost during my work.
mrxracing's Avatar
if not a hardware store, find a metal shop to make one or rethread the one you have
i know might not be much help but machine shops are the **** the do all kinds of miracle work
good luck bothah!!
Old 05-19-2004, 08:07 PM
Dan GSR's Avatar
Default Re: Metric Left Hand Thread Nuts (mrxracing)
if its for a swaybar endlink
don't even bother
cuz the endlinks won't spin anyway
Old 05-19-2004, 09:39 PM
oMek's Avatar
Default Re: Metric Left Hand Thread Nuts (Dan GSR)
ya i tryed lowes, they had lefthand standard size but no metric
and yes its for a swaybar endlink
look at the pics notice the 1 bolt diffrence. do i really need 1? if i cant find it i was gona have a shop weld it in place
Old 05-19-2004, 09:44 PM
esponet's Avatar
i don't see a reason why it would back out without the lock nut. the onlything i could think off is that it would be a stiffer conection with the lock nut. why don't you replace the whole thing. you could buy those at any hardware store. or if not try contacting a machine shop,hot rod shop, or a hardware store they might be able to help you locate the nut
Old 05-19-2004, 10:07 PM
oMek's Avatar
Default Re: (esponet)
i just figured that with out the lock nuts the 2 peices would turn with the swaybar and it moved and that cant be good at keeping in stiff
Old 05-20-2004, 01:05 AM
oMek's Avatar
Default Re: (oMekoneDC2)
ok well i just found 1 on some site for 1.10$ i hope its the right 1
Old 05-20-2004, 01:37 AM
oMek's Avatar
http://www.fastenal.com owns
Old 05-20-2004, 03:08 AM
tegmech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oMekoneDC2 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.fastenal.com owns</TD></TR></TABLE>
im looking through our book right now and i can't find any left hand threaded metrics. Can you even find it on our website? I hate these new catalogs they just gave us. Can't find a darn thing.
Old 05-20-2004, 11:43 AM
oMek's Avatar
Default Re: (tegmech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegmech &raquo;</TD></TR><TR><TD CLASS="quote">
im looking through our book right now and i can't find any left hand threaded metrics. Can you even find it on our website? I hate these new catalogs they just gave us. Can't find a darn thing.</TD></TR></TABLE>
ya on your site i searched for "m10 left" and it came up. i wint to 1 of your local stores and they said they gota order it form texas and it wont be here till wensday or friday of next week
Old 05-20-2004, 12:11 PM
Function7's Avatar
Jam nuts are not required for our endlinks. They are intended to be a little loose (just a hair) and they do not rotate since the linkage bolts hold them in place.
Please ensure that both sides are set "neutral" and that you have at least 5-7mm of thread threaded into the linkages.
Thanks
Old 05-20-2004, 12:24 PM
oMek's Avatar
Default Re: (Function7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Function7 &raquo;</TD></TR><TR><TD CLASS="quote">Jam nuts are not required for our endlinks. They are intended to be a little loose (just a hair) and they do not rotate since the linkage bolts hold them in place.
Thanks
you sure? i mean your endlinks looks almost exactly like comptech's and they use jam nuts.
i guess ill put them on without and see how i like it
Old 05-20-2004, 02:21 PM
Function7's Avatar
That's right. As long as you have them set correctly and ensure that the ends apply no preload on the swaybar when the car is on a flat surface the setup will be good.
Once you have them installed, you'll notice that the top half and the bottom half will be "loose" but they will not unscrew more than 1/4 turn from each other and the two halves will never disconnect because the two mounting bolts hold them in place.
Thanks
NOFX
35
08-11-2008 10:54 PM
GSRCRXsi
Welding / Fabrication
07-27-2006 04:34 AM
BoostinEJ1
18
07-02-2004 10:08 AM
vizsual00
10
06-01-2004 10:25 PM
Mr. Thunderlips
03-20-2003 10:18 PM
Quick Reply: Metric Left Hand Thread Nuts (reverse thread)
