check engine light is on and wont go over 3000 rpm
Old 05-13-2004, 11:47 AM
BRAWDY03's Avatar
Default check engine light is on and wont go over 3000 rpm
i recently changed my tranny, and everything worked fine until about 2 mins after its on the check engine light comes on and it runs like crap(wont go over 3000 rpm), i made sure all of my connections are plugged in about 50 times. a buddy of mine says it could be my map sensor and i called a couple of mechanics and they all said the same thing. and i also heard that theres a way to jump some wire to give me a code to tell me exactaly whats wrong with it, but i dont know how to do that either, can anyone give me advice???
Old 05-13-2004, 12:00 PM
Katman's Avatar
Default Re: check engine light is on and wont go over 3000 rpm (BRAWDY03)
Did you re-connect the ground wire that mounts to the tranny casing when reinstalling your trans ?
what year is your vehicle?
Old 05-13-2004, 12:52 PM
VtecDeMoN's Avatar
Well is your CEL coming on? If you don't know how to pull the codes, run a quick search of the archives.
Brian
Old 05-13-2004, 01:08 PM
Got_Saki60's Avatar
If your car is OBD-II (96 or newer) you can go to Auto Zone and they will hook in for free and tell you what the error is.
Old 05-13-2004, 01:24 PM
BRAWDY03's Avatar
Default Re: check engine light is on and wont go over 3000 rpm (Katman)
its an 0BD0 1990 civic sedan 1.5
Old 05-13-2004, 05:51 PM
hondaguyef's Avatar
Check your grounds especially, the one on the thermostat housing. I have seen this many times before. Also pull up your carpet and see which code it is throwing. Make sure if you do find a loose or disconnected ground that you reset your ECU
Old 05-19-2004, 11:29 PM
popngen's Avatar
bump bump any new developments? would help me out a lot... similar problem.. almost exact.. wrong p28 chip i think...
i haven't tripped the ecu plug with a paper clip...
Old 12-07-2009, 05:34 PM
Dominican000's Avatar
ok.. i got the same problem.. 2006 civic si.. the car was on a mini accident.. i fixed it.. changed the intake because the stock 1 was messed up... i had to buy the MAF sensor.. so i put it in... now it wont go over 3000 rpm with out the sensor connected.. when i connect the sensor the cars goes over 3000.. but shuts off... it wont stay on for more than 10 secs... i too it to auto zone.. the codes say the MAF and IAT is bad.. thats all.. but i bout the MAF brand new at the dealer.. what else could it be??
Old 12-07-2009, 08:30 PM
mouab18c1's Avatar
Jump your ecu and find what code its throwing.
https://honda-tech.com/forums/acura-integra-6/ecu-abs-codes-here-978933/
ElMaq
21
11-21-2017 08:39 AM
esoterEK..
10-02-2006 09:56 AM
egturbolsvtec
03-15-2006 03:20 PM
thenglishman
08-24-2004 08:50 AM
hybridEj6
10-08-2003 07:05 PM
Quick Reply: check engine light is on and wont go over 3000 rpm
