Old 05-01-2004, 06:49 PM   #1
nocturnaldragon
nocturnaldragon's Avatar
Send a message via AIM to nocturnaldragon
Default Changing the oil on a manual transmission
I drive a d16z6 so im asuming this would be true for other transmissions as well but after a few times of doing this i found the best way to change the oil is this:
(1) Remove the old oil via the drain plug and retighten (leave the drain pan for now)
(2) Remove the oil check bolt and set asside
(3) Remove the speedo sensor (Normally 1 10mm bolt) and set aside
(4) Get a nice long funnel or a hose that ataches to the oil can with a cut off like i ussed
(5) pure 2qts. of oil into the tranny thro the speedo sensor opening untill full - you'll see oil coming out of the oil fill/check bolt
(6) Reatach the speedo sensor and replace the oil fill bolt and check for leaks
- You can skip step 3 and use a piece of hose to attach the funnel to the breather tube, but its more difficult making an adaptor and slower because of the smaller opening inside the tranny "O <-Propably that size litterly inside, its meant for a breather not to fill it."
Enjoy!
After replacing my tranny 4 times last month and trying different ways of filling it with oil i found this to be the easiest with the least amount of spillage and mess
My paint project (56k uncertain) - http://www.honda-tech.com/zerothread?id=1262071
Del Sol Pro's and Con's The official end all thread. - http://www.honda-tech.com/zerothread?id=1273946
Originally Posted by flowbee
I wont lie, I've whacked it to a video game before
nocturnaldragon is offline Report Post   Reply With Quote
Old 05-01-2004, 06:51 PM   #2
Mike_C
Moderator
Mike_C's Avatar
i assume you meant the fluid? i know you can use oil in it's place, but i don't want people to be confused - "there's oil in my tranny!?!?!"
http://www.iammike.org
XBOX: iammikeDOTorg
I put more miles on my body than my vehicles.
Current: 93 Civic, 97 VFR, 01 Big Sur, 05 TCR2, 09 1x1
Past: 01 S2000, 91 Accord, 86 Delta 88, 95 Integra
Mike_C is offline Report Post   Reply With Quote
Old 05-01-2004, 07:03 PM   #3
nocturnaldragon
Default Re: (MichaelJComputer)
Mine calls for 5w-30 or 10w-40 engine oil in my honda service manual so, But im assuming theres not much difference between motor oil and manual transmission fluid all they do is lubricate the gears and what not like the oil does in the engine block........
Old 05-01-2004, 07:04 PM   #4
Mike_C
Moderator
Mike_C's Avatar
ya ya, i know. i assume some people don't know that though, don't want to confuse them.
XBOX: iammikeDOTorg
Old 05-01-2004, 07:56 PM   #5
743power
743power's Avatar
Send a message via AIM to 743power
Default Re: (nocternaldragon)
Actually honda made a service bulletin and recomends using honda MTF now. Alot of dealers dont even stock it, and still use oil. I only use the MTf. It's about the same price as a quart of synthetic oil. It's alot thicker, and smells like absolute hell.
"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
-Albert Einstein
743power is offline Report Post   Reply With Quote
Old 07-09-2004, 04:32 PM   #6
chronodyne28
chronodyne28's Avatar
Send a message via AIM to chronodyne28
Default Re: (743power)
Can anyone post pics on how to do this, please?
chronodyne28 is offline Report Post   Reply With Quote
Old 10-27-2004, 12:36 AM   #7
lDanny
lDanny's Avatar
Default Re: (chronodyne28)
last time i got it done.. they used some kind of pump?
vouches:
http://www.honda-tech.com/zerothread?id=790000
search under my name, I have A LOT of stuff for sale
http://hondamarketplace.com/ze...age=1
Need your brakes change or rotors done... let me know...
lDanny is offline Report Post   Reply With Quote
Old 03-28-2005, 10:56 PM   #8
BLUE EH3
Help we my pennies
Send a message via AIM to BLUE EH3
Default Re: (lDanny)
cant u fill the tranny , but useing the hole on the side!!
BLUE EH3 is offline Report Post   Reply With Quote
Old 03-28-2005, 10:57 PM   #9
BLUE EH3
Help we my pennies
Default Re: Changing the oil on a manual transmission (nocternaldragon)
Old 03-28-2005, 11:51 PM   #10
civictildeath
civictildeath's Avatar
i didnt realize this to be a problem that required a DIY writeup.
i would never use anything in my tranny other than tranny fluid. the call it engine oil for a reason, it goes in the engine!!
if it smells bad, it must be the better stuff ad the power steering fluid you can not use ATF fluid for because it screws it up im not sure why but was told this by very upstanding mechanics
sounds like you have a driving problem not a tranny problem.
RIP Bubba 5-27
ECU CODES
O2 Sim Install
SUSPENSION
CHASIS
<FONT COLOR="blue">1999 EM1</FONT>
<FONT COLOR="red">1997 EJ8</FONT>
<FONT COLOR="blue">1993 Sol SI</FONT>
3rd gear grind member #8
civictildeath is offline Report Post   Reply With Quote
Old 08-05-2006, 04:58 PM   #11
BLUE EH3
Help we my pennies
Default Re: Changing the oil on a manual transmission (civictildeath)
What is a "the oil check bolt "
Old 08-05-2006, 05:05 PM   #12
b20eghatch
b20eghatch's Avatar
Send a message via AIM to b20eghatch
i need some pics
b20eghatch is offline Report Post   Reply With Quote
Old 08-05-2006, 05:05 PM   #13
chrisw85
chrisw85's Avatar
motor oil is not the most suitable for use as a transmission lubricant. It does not contain the proper EP (extreme pressure) additives and other wear additives that a puropse designed transmission/gear/axle fluid does.
Try putting regular dino motor oil 5w30 into your transmission and then use a good quality synthetic like Amsoil 5w30 MTF synchromesh transmission fluid. Night and day difference. I used to run Redline MTL, but the amsoil MTF has been butter, more so than the MTL in my opinion.
chrisw85 is offline Report Post   Reply With Quote
Old 08-05-2006, 05:27 PM   #14
b20eghatch
b20eghatch's Avatar
what does the spedo look like on the tranny i need a pic
Old 09-15-2006, 12:53 PM   #15
killakoupe
killakoupe's Avatar
Location: San Diego to Palm Springs Runnin Things, CA, USA
Send a message via AIM to killakoupe
x2
killakoupe is offline Report Post   Reply With Quote
Old 09-15-2006, 01:20 PM   #16
SkoundrelUSA
SkoundrelUSA's Avatar
Default Re: (killakoupe)
Tom I borrowed your pics
Its really really easy.
Jack the car up
Then grab your 3/8" socket wrench and loosen this bolt (the "square one" that your socket wrench will fit)
See how it pours out
Then after its all out you can do it 2 ways
1) Thread the bolt back on, lower the car and fill it back up with 2.3-2.5 qts of oil(I'll get to the filling in a sec)
or Thread the bolt back on, but UNTHREAD the fill plug (picture below), lower the car so its "level" with the ground, begin filling it up until oil pours out the filler hole, and then thread it back
The reason I say this is because with the car down its more accurate as to how much oil is actually in there. But its also a pain in the ass IMO to keep jacking the car up and down and up and down.
Next unplug and unbolt the VSS.
To unbolt theres 1. I repeat 1 10mm bolt closest to the driver's side thats holding it onto the tranny.
Then just bolt back on the VSS and the drain bolt (depending on which way you decided to do it) and you're done! Don't forget to plug the VSS back on or there won't be any VTACK!!!!
Modified by SkoundrelUSA at 9:29 AM 9/16/2006
"So whats the deal with politics? I don't get it...Am I right people? "
SkoundrelUSA is offline Report Post   Reply With Quote
Old 09-29-2007, 12:45 PM   #17
HondamanXxX
GO GIANTS!
2008 Porsche 911
HondamanXxX's Avatar
Default Re: (SkoundrelUSA)
Does the VSS pop up? Mine is stuck to the tranny.
Flickr
Originally Posted by Ash J. Williams View Post
by the amount of colour of your avatar, font and signature, i'd say you are bloody high on something indeed.
HondamanXxX is offline Report Post   Reply With Quote
Old 09-29-2007, 01:02 PM   #18
HeikDiesel
HeikDiesel's Avatar
Send a message via AIM to HeikDiesel
Default Re: (HondamanXxX)
Its just held in by the 6mm bolt and a o-ring
PSN- HeikDiesel
David Pittman at R&D Motorsports scammed me for $2,000
HeikDiesel is offline Report Post   Reply With Quote
Old 09-29-2007, 01:13 PM   #19
HondamanXxX
GO GIANTS!
2008 Porsche 911
Default Re: (HeikDiesel)
Wierd how I took out this bolt buts a bitch to get out. I wiggled and wiggled and not moving an inch!
Flickr
Old 09-29-2007, 04:17 PM   #20
HeikDiesel
HeikDiesel's Avatar
maybe the metal galded to the transmission case. Try a pry bar and be easy maybe?
PSN- HeikDiesel
Old 10-02-2007, 10:26 AM   #21
hatch_
hatch_'s Avatar
my VSS is stuck to the tranny too. it wont move at all. is there any other way i can do this without the removal of the VSS?
hatch_ is offline Report Post   Reply With Quote
Old 10-02-2007, 10:40 AM   #22
hatchling37
hatchling37's Avatar
Default Re: (hatch_)
Grab a long skinny tube, and attach it to a funnel and run it into the fill hole. Then dump in MTF or equivalent until it starts to run out of the hole. You can't overfill it, the exact level is where the hole bottom is. This is (like was said) kind of a pain, because then, if you aren't on a lift or lifted evenly on jackstands, you have to raise the front end to get under it to put the bolt back in there.
'97 CX - Gone '94 LS - Beater '08 CR-V EX - Wife
ASE Certified
hatchling37 is offline Report Post   Reply With Quote
Old 10-02-2007, 10:49 AM   #23
jdm91CrxSi
jdm91CrxSi's Avatar
Send a message via ICQ to jdm91CrxSi
Default Re: (b20eghatch)
no mean to bump in your thread but about two weeks ago i changed my tranny oil. usually i just go with some regular highmilage 10w-30. usally a pretty smooth transaction.. but i wanted to change it up. some one told me to never put full synthetic in. why? so i had to prove them wrong. went to oriellys and bought two quarts of royal purple 10w-40 and put it in the tranny. and matter of fact i can feel a great diffrence in transactions. feels pretty damn smooth in the d15. sorry btw
2002 Acura Rsx Type-S- Current
1991 Honda Crx Si ZC turbo - SOLD
1994 Civic Coupe - OBD1 DOHC ZC, t3/43, 237whp / 8psi
jdm91CrxSi is offline Report Post   Reply With Quote
Old 10-02-2007, 10:51 AM   #24
neocrynym
neocrynym's Avatar
Send a message via AIM to neocrynym
Default Re: (hatchling37)
Or you can just fill it via the transmission's vent at the top and eliminate all this removing the VSS mumbo jumbo. In the time it takes you to remove (and possibly damage) the VSS, you'd already have it filled through the vent.
'04 ABP TSX *Current*
'92/'93 FBP CX/Si *Missed*
My FS & vouches thread
neocrynym is offline Report Post   Reply With Quote
Old 10-02-2007, 11:20 AM   #25
B18C5-EH2
Moderator
B18C5-EH2's Avatar
Send a message via AIM to B18C5-EH2
Default Re: (jdm91CrxSi)
"I heard not to use full synthetic in my tranny, so the very next thing I did was go and put synthetic fluid in my tranny!"
The way that manual transmission synchros work is like a cone that another piece slides down onto and locks into place - this action requires a certain level of "friction" so to speak, and if all of that advertising about synthetic oil "bonding to parts" and " provides the best protection against friction" etc. is all true then that is why I'd agree that I'd never put synthetic oil in my transmission.
I personally use and recommend Genuine Honda MTF as evidenced by that pic up there of me pouring it into my Type R transmission. You spend less than synthetic oil, and you KNOW you're using what Honda/Acura intended to be in the transmission anyways.
B18C5-EH2 is offline Report Post   Reply With Quote
Bookmarks
10w40, 2005, accord, acura, change, changing, civic, del, fill, honda, location, manual, oil, overfill, plug, purple, royal, sol, tl, transmission
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Honda-Tech.com content, comments, or iPad advertising. Honda-Tech.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Honda-Tech.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
