how to identfy vtec & non vtec distributor
hey guy i got a dizzy and want to know .if theres any way that i can find out if its a obd 1 vtec dizzy any help would be good thanx
Re: how to identfy vtec & non vtec distributor (typeR 507)
Well I'm going to assume you're talking B-series in which case, LS dizzy has 3 legs spaced equally apart, VTEC dizzy has two legs somewhat close and the third is visibly offest from the two others.
Stamped into the side of every honda distributor there is a code that starts with "TD" then two numbers, then a "U".
For example, if it is a GS-R or B16A OBDI dist it will say TD-44U.
Tell us the code, and we can tell you what type it is!
check it out. Appears to be OBD1 vtec
http://www.andale.com/store?si...CatId=
TD-32U is the 90-91 ls one
vtec25
11-07-2007 03:55 PM
check, civic, distributer, distributor, distributors, harnass, honda, id, motor, nonvtec, obd0, series, type, vtec, wiring
