how to identfy vtec & non vtec distributor
Old Feb 13, 2004 | 02:08 PM
typeR 507's Avatar
Default how to identfy vtec & non vtec distributor
hey guy i got a dizzy and want to know .if theres any way that i can find out if its a obd 1 vtec dizzy any help would be good thanx
Old Feb 13, 2004 | 02:53 PM
RedlinedVTEC's Avatar
Default Re: how to identfy vtec & non vtec distributor (typeR 507)
Well I'm going to assume you're talking B-series in which case, LS dizzy has 3 legs spaced equally apart, VTEC dizzy has two legs somewhat close and the third is visibly offest from the two others.
Old Feb 14, 2004 | 09:26 AM
streetimports's Avatar
Stamped into the side of every honda distributor there is a code that starts with "TD" then two numbers, then a "U".
For example, if it is a GS-R or B16A OBDI dist it will say TD-44U.
Tell us the code, and we can tell you what type it is!
Old Feb 15, 2004 | 09:02 AM
typeR 507's Avatar
Default Re: how to identfy vtec & non vtec distributor (streetimports)
its says TD-68U
Old Feb 15, 2004 | 10:06 AM
85mm LsVTEC's Avatar
Mine says TD-32U. What kind is that?
Old Feb 15, 2004 | 09:11 PM
Runnerdown's Avatar
check it out. Appears to be OBD1 vtec
http://www.andale.com/store?si...CatId=
TD-32U is the 90-91 ls one
Old Feb 15, 2004 | 10:02 PM
TD-44U and TD-68U are the same, fully interchangable.
Old Feb 16, 2004 | 05:19 AM
typeR 507's Avatar
cool thanx guys
Alexpbnj
May 16, 2011 04:36 AM
vtec25
Nov 7, 2007 03:55 PM
D-rush08
Sep 7, 2006 10:08 AM
Speed94
Mar 18, 2005 08:19 PM
91hatch_on17's
Jun 25, 2003 10:26 PM
