How do you bleed the air out of the cooling system?!?!
Old 01-02-2004, 03:52 PM
Red D Dragon's Avatar
Default How do you bleed the air out of the cooling system?!?!
I have a skunk2 manifold on my gsr and when it warms up the RPMS surge up and down and i was told it could be because of air in my coolant system so if someone could tell me how to bleed the system so there is no air in it and if there is anything i should check for to fix my problem. thanks.
Old 01-02-2004, 04:22 PM
K20EG's Avatar
Default Re: How do you bleed the air out of the cooling system?!?! (Red D Dragon)
if there is a valve on the upper radiator hose neck ..loosen that a bit that will help you bleed it quickly. * you might wanna hook a small piece of bulk fuel line or small heater hose to it and route the excess to a cup or somethin
Old 01-02-2004, 04:37 PM
onePOINTsix's Avatar
Default Re: How do you bleed the air out of the cooling system?!?! (K20EG)
i posted this like a hour ago
Old 01-02-2004, 04:40 PM
K20EG's Avatar
Sorry bro ...i saw it and no one posted yet
just trying to help out
Old 01-02-2004, 09:31 PM
Damn thanks. I would have never though to run it with the radiator cap off but i will try it tomorrow and tell you if it solves my problem. thanks again.
Old 01-04-2004, 01:15 AM
iam7head's Avatar
Default Re: (Red D Dragon)
isn't there a bleed valve? on the highest point of the cooling system?
I just flushed the cooling system on my 89 legend and the air bleed is on the where the thermostat at, right after the radiator hose(upper)
Bill Leland
06-12-2014 02:29 PM
darkblackH2B
12-15-2008 07:08 PM
twenty
07-15-2005 12:47 PM
return_2020
12
02-12-2005 05:51 AM
DFW
01-29-2005 07:57 AM
Quick Reply: How do you bleed the air out of the cooling system?!?!
