Quick Check Engine Compression ratios
Old 11-19-2003, 03:26 AM
ace1875's Avatar
Default Quick Check Engine Compression ratios
The Calculation of an engine's compression ratio ( C.R. ) is based on the formula :
CR= (SV+CV)/CV
SV= Swept Volume for one cylinder in CC's= Bore x Bore x stroke x 12.9
CV= Clearence Volume for one cylinder in CC's= HV minus EDV plus DV plus GV
HV= Head Volume (measured in CC's)= Best if measured because head volume vaires
EDV= Effective Dome Volume (measured in CC's)= Dome volume minus valve relief and/or dish volume
DV= Deck Volume clearance (piston to deck) (measured in CC's) = Bore x Bore x Deck Height x 12.9
GV= Gasket Volume (measured in CC's)= Gasket Bore x Gasket Bore x Compression Thickness x (12.9 or enter known gasket volume)
edit: Cubic Inch Displacement measurement
Bore x Bore x stroke x .7854 x 4(cylinders)
Thought this should be in H-T to be archived if someone needs these formulas. If anyone have anymore usefull formulas please feel free to post them.
Thanx
Ace
blackhbkid
01-29-2009 08:21 AM
WorrGame13
03-30-2007 03:35 PM
Takumi Fujiwara
26
04-16-2005 04:22 AM
OEMcivic
01-05-2005 08:20 AM
fredtoast
02-17-2004 04:42 AM
Quick Reply: Quick Check Engine Compression ratios
