[FAQ] DIY How-To: Install Civic 92-95 Amber/Red Dash Lighting (56k no no)
#926
Re: [FAQ] DIY How-To: Install Civic 92-95 Amber/Red Dash Lighting (56k no no)
Just a quick tip, go back a few pages and read my posts. I know everyone wants to do this however it doesn't last and the color is crappy. The way I did it came out great and i posted a link on how I did it. I advise you guys to do it the same, even if its a little more work. The way the OP did it is not a very good method and I just want you guys to be aware
I think people are seeing the picture I posted and assuming thats using the method posted in this thread, which it isnt. It was done completely different.
Pm the link there's too many pages.
#927
#929
Hey i have a 92 accord LX, and i want to paint my cluster lights amber,and temp control aswell, does anyone know how many lights i'll need? and what number?
#930
#933
The Grumpiest
Might want to check in the Accord forum.
https://honda-tech.com/forums/honda-accord-crosstour-2003-2012-118/
#937
I need to do this.. Previous owner installed like 3 different color bulbs.
#938
To get the ***** off the face plate you need to get your fingertip under the **** and gently lift until you feel a click, Then go to the other side of the **** and lift up with your other hand.
#939
How did you remove the bulbs from the climate control? Did you just pull it or what? Im not sure how to remove them.
#941
I turned the CC over and slid the sliders over to the far sides to get a better grip on the bulb socket lead wires and gently popped them out the backside - yes the bulb/socket units do remove safely that way. It is easier to remove the bulb when you can grip the base.
#942
Does any one know how to get to the other bulbs that light up on the button when it is pushed. They are green but I think the A/C one is orange. One of those went out on mine and I need to figure out what kind of bulb it is and how to get to it.
#943
Well distributed lights with a 1.5meter long led strip!
The gauges: I used a dremel. It happens that the OEM gauges have this blue painted cover that diminishes the light and makes it blueish.
Also, every bulb was replaced with a led! The lights from the high beam, turn signals, SRS, seat belt etc are very bright now
I added a led light for that nickel drawer below the radio.
Plus, I waxed the cluster glass.
#945
I didn't read all the posts but can you tell me if that set up is dim-able? Thanks.
Looks great BTW!
Looks great BTW!
#946
#947
PLEASE,
can somebody explain me HOW to do this:
The f***** needles light up!!!!
How!?!?!?
Once, I tried to take the needles off of the gauges to replace with 96 civic needles, which light up.
Well, it didnt work out. I broke all of them and had to buy another cluster.
So, does anybody know how to make the needles light up!?
Because, honestly, this would be f******* sexy for a 1995 car!
How!?!?!?
#949
#950
Risky Business
If you had told me in 2003 when I wrote this thread that it would still be getting replies 11 years later, I would have **** myself.
Then again, if you told me I'd own a Corolla when I was 30, I probably would have **** myself as well.
