#1 | |||||
#2 |
Skoobie no more...
u tried searching ? I doubt it i just did a mpfi swap a month ago and i found all info on this site. i just pulled 277 results when i searced for mpfi.
anyways go to http://tech.hybridgarage.com/t...g.htm will answer all your questions. |
#3 |
What do I care, I drive a 4G Si, give me a few months i will smoke your ass. In works built B16A spinning 9600RPM with Toda 1.8L storke http://images.honda-tech.com/set1/smile/emsmilep.gif |
#4 |
You are going to have to mate parts of the Si harness to your stock DX harness. If you need one built then let me know.
Moderator on http://www.crxohio.org |
#5 |
Hey I need one built. IM me.
#6 |
its a super easy job. you can do the mpfi swap without chaning the head at all it you want to. some people swear you cant do it without swapping cam/cam gear,but you can. you need the intake manifold, distributer, and all the injectors/fuelrail/throttle body for the si. put that stuff on, do the wiring swap(simple) and plug in the mpfi ecu and your done. for the wiring, you'll need to run 4 wires through the firewall(go through where the ac lines normally do, if you dont have ac, you'll have a rubber plug in the spot). those 4 wires need to be tapped into some stuff, i'm not goin into it right now though, you can search for that sort of thing yourself. its really not difficult.
custom EF traction bar and a cheap K24 for sale too! PM! WTB: useable h22 of h23 block/girdle..no crank needed |
#7 |
I'm going to be doing the DPFI->MPFI conversion soon and it's the wiring I'm still sketchy on. I've searched the site, done the links but I'm just iffy on the whole wiring portion. I guess I'll figure it out as I go hahaha
#8 |
See below for updated links:
Modified by 88DXCRX at 3:25 PM 3/31/2005
living that automotive dream |
#9 |
#10 |
go to page 2 or 3. this kid ask the same questio, the answer in that page.
#11 |
#12 |
New to the site Im doing a mpfi sowap on my DX. I have ben reading and it seid that I can get the wires from the cilender position sensor out the stooc distributer but what coller are theyand in what order do they go thanks.
#13 |
thanks alot ill just go and buy the si distributer
#14 |
Hey I need help! I have been searching for about a month. I got all the parts for mpfi swap. I put everythinng in and I followed the instructions but the car is all retarted. It doesn't want to stay on! And the check the engine light stays on. PLEASE HELP!!!
#15 |
double check all your wiring
#16 |
Ok I checkt everi ting and it steel runing like shet and the check engen light staise on what ells can it be the ecu burnt or what.Help!!!
#17 |
holly shit you attempted the mpfi swap before learning to type......
what computer are you running? have you checked to see WHICH codes it's throwing? have to tried another resister box? maybe yours is bad. same with injectors.
<FONT COLOR="blue">'98 Suburban STOCK 10 MPG '89 Wrangler 39.5" Super Swamper Boggers and 4 cylinders SLOW '89 CRX DX with 83k miles, cage, omni's, corbeau's, si tranny, 39 MPG SOLD '79 Civic 1200 56.9 whp 60.1 ft/lbs of Torque SOLD '96 Integra SE Fully Built Turbo DFI Gen 7 SCAMMED </FONT> <FONT COLOR="black">-----------------------------------------------------------------------------------------------</FONT> <FONT COLOR="red">Vouch Thread</FONT> |
#18 |
I'm running a pm6 ecu from a 89 civic. I haven't checked the codes. How do you check the codes?Should i get new injectors and resister box?
#19 |
If you dont feel 100% confident, have rywire do it for you http://www.rywire.com
Ryan
Droppedcrxsi.com for B16 / B18 / K20 Swap Info rywire.com skunk2.com karcepts.com |
#20 |
How much would it cost?
#21 |
What codes are you throwing in the first place? It could be something really simple.
If a law is unjust, a man is not only right to disobey it, he is obligated to do so. SWED |
#22 |
I checked the codes and it's trowing code 9 and 14. What should I do?
#23 |
I checked the codes and it's trowing code 9 and 14. What should I do? please let me know.
#24 |
9* Accord 85-98** Civic 86-98 CRX 85-91 Del Sol 93-97 Prelude 85-98
Cylinder Position (CYP) Sensor Defective cicuit or unplugged/defective sensor *N/A to any throttle body injection Honda's **N/A to V-6 engines 14 Accord 88-98 Civic 88-98 CRX 88-91 Del Sol 93-97 Prelude 88-98 Idle Air Control (IAC) Valve Defective cicuit or unplugged/defective sensor
#25 |
Know geting codes 10-9-14and16 how can I fix all this shit
| Bookmarks |
| Tags |
| automatic, code, conversion, crx, crxohioorg, dpfi, dx, honda, iac, info, injector, mpfi, mpfii, resister, sale, swap |
