Classic Hondas All Pre-1988 Hondas.
Engine Coolant Temperature sensor on '88 Accord LXi
Old 09-09-2003, 07:54 AM
mjkibbe1027's Avatar
Default Engine Coolant Temperature sensor on '88 Accord LXi
I own an '88 Accord LXi that was having erratic idle problems, and often would not start when hot. The problem finally got bad enough to trigger the CEL. ECM is now giving me code 6 (ECT sensor). When I went to check it out, I discovered there are two sensors in the thermostat housing (beside the temp sending unit) and I'm not sure which one or if both could be the problem. If anyone out there could help me out, I would be very grateful.
PS - 2.0 4 cyl
PGM-FI
Old 09-09-2003, 08:10 AM
Stew Pidasso's Avatar
Default Re: Engine Coolant Temperature sensor on '88 Accord LXi (mjkibbe1027)
I'm sorry I don't have an answer for you but you might want to ask this on http://3geez.com . It's a site dedicated to 3rd generation accords (86-89). Good luck
Old 09-10-2003, 12:00 AM
Stripped Honda's Avatar
i looked in my honda factory service manual and didnt see any sensors called the ect sensor .. i would reset the ecu and look for other problems that the car may have ..... check for a possible intake manifold leak or a vaccum leak those are the problems your most likely to have
Old 12-23-2023, 06:14 AM
SamKCMO's Avatar
PS - 2.0 4 cyl
PGM-FI
you ever figure it out? I have the same problem
Babong
17
09-20-2011 08:35 AM
doitmyself2010
11
06-26-2011 12:55 PM
robdog09
09-08-2009 09:26 PM
EkS
05-09-2007 01:06 PM
Quick Reply: Engine Coolant Temperature sensor on '88 Accord LXi
