Clicking noise when applying brakes (HELP!!)
Old 08-16-2003, 04:22 PM
AccordOn18z's Avatar
Default Clicking noise when applying brakes (HELP!!)
hey guys when i step on my brakes it sounds like a clicking noise..and i cant findout what it is...i put it on the lift today at work and its not the inner or outer tie rods and my brakes are intact fully..i have a 96 accord Lx i just wanted to know if anyone has had this problem and what i could be....thanks guys
Old 08-16-2003, 04:42 PM
im_the_teacher's Avatar
Default Re: Clicking noise when applying brakes (AccordOn18z)
make sure the tie rod is tight (strut rod) connect to the strut.......if the tie rod is tight.......
most honda brakes make clicking noise.......that normal...
Old 08-16-2003, 04:44 PM
cd7.h22
Guest
Posts: n/a
it could be many things it could be that one of the bolts to the rims arent on tite. your have heat strokes marks on your rotors something down there is loose so make sure everythings tight let me know wussup
Old 08-17-2003, 06:17 PM
gooberwolf's Avatar
it could be the wheel bearings - that was the case w/ my 92 accord.
Old 08-18-2003, 10:32 AM
cd7.h22
Guest
Posts: n/a
Default Re: Clicking noise when applying brakes (gooberwolf)
how hard was that to fix and did you fix it yourself im starting to hear clicking noises when i drive slow now too damn JINXED
JasonMD
04-22-2018 10:19 PM
GuitarPunk015
09-09-2009 10:19 AM
Prince6599
02-19-2006 02:42 PM
allanonjj
06-28-2005 02:43 PM
ef_you
12-25-2004 09:41 PM
Quick Reply: Clicking noise when applying brakes (HELP!!)
