FAQ: D15 SOHC VTEC Mini-Me : Massive Write-Up (56k Goodbye)
Old 11-26-2012, 07:47 PM
  #676
greddy1387's Avatar
Default Re: FAQ: D15 SOHC VTEC Mini-Me : Massive Write-Up (56k Goodbye)
i keep hearing with the d15 bottem end and z6 head time is off 4 degs. that u need to run a y8 cam gear on the z6 head is this true
greddy1387 is offline
Old 12-02-2012, 02:47 PM
  #677
stobby08's Avatar
Ok nice write up I need some help I'm currently working on the same project and I've got the motor all tore down to the block and I'm takin it to the machine shop next week to get honed and cleaned up any idea on pistons? I'm not building it to race its gonna be a daily driver but I know how it drove with the stock head and I just want some more power I was thinking maybe some high compression pistons and maybe a stage one cam not gonna change internals the head has already been shaved but I'm not sure how much was took off any suggestions???
stobby08 is offline
Old 12-02-2012, 03:43 PM
  #678
The Grumpiest
grumblemarc's Avatar
This thread is about simply swapping heads. Not about upping compression or changing out pistons. I would suggest looking into the All Motor forum but from MY research, you're wasting your time all the way around.
grumblemarc is offline
Old 12-20-2012, 06:32 AM
  #679
94lowridingcivi's Avatar
Im running a d15b6/z6 mini me and trying to do the timing but i know its a half tooth off so how to make up for that???
94lowridingcivi is offline
Old 12-24-2012, 11:48 AM
  #680
Funktastic0177's Avatar
Can anyone help me out with some info? I have a z6 head going on a d15b2 block and I need to know which exhaust manifold and downpipe to use.
Funktastic0177 is offline
Old 12-24-2012, 11:49 AM
  #681
Also, what would cause the idle to be at 2500? I know i'm going to need to fix that soon.
Old 03-31-2013, 07:24 PM
  #682
WKhbnrd's Avatar
awesome write up! thanks.
WKhbnrd is offline
Old 03-31-2013, 09:33 PM
  #683
tcleghorn's Avatar
Good write up. I wish this would have been around when I built my first mini me about 7 years ago
tcleghorn is offline
Old 04-02-2013, 05:30 AM
  #684
Risky Business
BauleyCivic's Avatar
It was written 10 years ago.
BauleyCivic is offline
Old 04-19-2013, 06:30 PM
  #685
Sean EgHatch909's Avatar
Good write up hoping to start mine this weekend trying to keep it around the same budget
Sean EgHatch909 is offline
Old 09-20-2013, 07:18 AM
  #686
jollygreengiant's Avatar
so overall what other effects did this have on your car other than a little bit better low end torque and the VTEC benefits? any difference in fuel mileage? tings of that nature.
fyi im not necessarily new to cars, i know a little bit, basics, just nothing about hondas, hence my joining this forum :D
edit: sorry, old thread i know..
jollygreengiant is offline
Old 10-08-2013, 02:29 PM
  #687
Markus Mendez's Avatar
I'm doing a mini me right now I'm in the wiring part like the distributor, fuel injectors, and the ecu i was wondering if i can use a stock vtec manual ecu in a dx with the dx wiring all i would have to do it wire the vtec the same way i would with a chipped ecu right? could i do that, feed back pleaaase!.
Markus Mendez is offline
Old 02-21-2014, 03:45 AM
  #688
WFTB's Avatar
i have the same block as you .how did your build go? got it done yet ? thanks
WFTB is offline
Old 09-14-2014, 11:49 AM
  #689
RyanCharlie's Avatar
I used this guide for my build and it was very helpful! Thanks man!
RyanCharlie is offline
Old 01-30-2015, 02:56 PM
  #690
Aguywhomatters's Avatar
will all this info work on a d16a6 block instead of a d15b7
Aguywhomatters is offline
Old 02-04-2015, 10:14 AM
  #691
Lasty K's Avatar
D16A6 to D16Z6 Conversion..."Mini-Me"
I'm guessing that might help?
Lasty K is offline
Old 05-24-2015, 08:21 PM
  #692
dave240z's Avatar
nice write up but wouldn't it be easier to just go full swap zc for the price?
dave240z is offline
Old 08-07-2015, 06:33 AM
  #693
dailyej6's Avatar
I'm doing the same swap except with a y7 head I just wanted to ask what p/s will I need? because my y7 P/S isn't bolting up right.
dailyej6 is offline
Old 08-21-2015, 11:11 PM
  #694
JOKERSOL's Avatar
How can i get the oil jet out? With what socket? Thanks in advance.
JOKERSOL is offline
Old 08-22-2015, 06:01 AM
  #695
I like the tuna here
DumpdEJ6's Avatar
I don't think you use a socket, it should slide right out if you can get a grip on it. Maybe try using a pick or a pair of needlenose pliers.
DumpdEJ6 is offline
Old 01-11-2016, 09:19 PM
  #696
haystacks's Avatar
Will this swap work on a 88-91 hatch?
haystacks is offline
Old 02-25-2016, 04:29 AM
  #697
92_civic_eg's Avatar
What do i need for ignition distributor? i cant use the stock d15b7 distributor on the z6 head? does it need a new cap or the whole thing?
92_civic_eg is offline
Old 05-30-2016, 04:47 AM
  #698
Shiwa's Avatar
Default Re: D15 SOHC VTEC Mini-Me : Massive Write-Up (56k Goodbye)
nice something i can use
Shiwa is offline
Old 10-22-2016, 10:49 PM
  #699
cole burks's Avatar
Does anyone know what timing belt i use on this conversion? D15b7 with d16z6 do i use the d15 on the bottom and d16 on top? Shaving of any of them?
cole burks is offline
Old 10-23-2016, 06:55 AM
  #700
Former User's Avatar
Honda-Tech - Announcements in Forum : Honda Civic / Del Sol (1992 - 2000)
Former User is offline
kinkyintegra
Northeast (Sales)
11-14-2008 08:53 PM
screen_name
02-01-2006 07:59 AM
TheAutoboxer
23
04-17-2003 09:47 PM
Civic89
12
07-06-2002 10:29 AM
86CRXSi
06-11-2002 04:27 AM
Quick Reply: FAQ: D15 SOHC VTEC Mini-Me : Massive Write-Up (56k Goodbye)
