torque specs for valve cover bolts?
Old 06-08-2003, 07:07 PM
twkdCD595's Avatar
Default torque specs for valve cover bolts?
getting a little oil on one side of the valve cover... whats the correct torque specs... I think I have it wrong.
Thanks.
twkdCD595 is offline
Old 06-08-2003, 08:13 PM
fizzbob7's Avatar
Default Re: torque specs for valve cover bolts? (twkdCD595)
just torque them down where they're good and tight...you don't want the gasket to squish out....but do it in a pattern so that they all get torqued evenly....and snug them all in that pattern, then go back and tighten them down in the same pattern....i've never seen anyone use a torque wrench on that....you can, but to me that's to "by the book" for me....the pattern is as important as anything...do the left one on the front, then the right one on the back, then do the left one on the back, right one on the front, etc....work your way in....
fizzbob7 is offline
Old 06-08-2003, 08:44 PM
twkdCD595's Avatar
thanks but I was looking for more than the guesstimation method.
Old 06-08-2003, 08:46 PM
GimpyAccord's Avatar
83 inch pounds.
GimpyAccord is offline
Old 06-08-2003, 09:36 PM
iam7head's Avatar
Default Re: torque specs for valve cover bolts? (GimpyAccord)
I dont have a torque wrench anymore..
just took my valve cover off 15 min ago.
10 revolution with my sockey wrench.
iam7head is offline
Old 06-08-2003, 09:47 PM
fizzbob7's Avatar
Default Re: torque specs for valve cover bolts? (iam7head)
guesstimation works dude
seriously....the pattern makes a huge difference....get them tight and bam...they're small, so don't break them....it's completely "not hard" at all
fizzbob7 is offline
Old 06-09-2003, 06:48 PM
twkdCD595's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GimpyAccord &raquo;</TD></TR><TR><TD CLASS="quote">83 inch pounds.</TD></TR></TABLE>
you mean foot lbs?
Old 06-09-2003, 07:53 PM
SOHCMAN's Avatar
nope, its inch pounds....83 inch pounds, but when you do it do a patter with about 50 inch pounds first, then go the full amount... its just a good practice.
sohc
SOHCMAN is offline
Old 06-09-2003, 07:57 PM
SOHCMAN's Avatar
OH, and make sure to put beads of high temp PTF gasket stuff in the right angles were the cam is , and MAKE SURE to wipe all oil from both of the surfaces (both the head where the gasket will touch and the gasket itself) that might have been why you had the leak in the first place
sohc
SOHCMAN is offline
Old 08-15-2015, 10:28 PM
Trunkzdbz's Avatar
It's exactly 7 foot pounds or 83 inch pounds, which ever is on the torque wrench you have, and never use guesstimation when it comes to your car. I have a 1996 Honda Accord and have done a ton of work on her myself and I never use guesstimation, that's for losers who don't have the brains and the ***** to do the job right like we like too, good luck.
Trunkzdbz is offline
Old 08-17-2015, 07:12 AM
denierlexiese's Avatar
7 ft/lbs torque. I'm doing my valve cover right now too. You guys have any advice how to make sure the spark plug well grommets secure?
denierlexiese is offline
Old 08-17-2015, 01:52 PM
holmesnmanny's Avatar
You just want it snug, it's not imperative to get it exact. If you overtighten it it's really easy to snap the stud so just snug the nuts in a crisscross formation from the inside out.
holmesnmanny is offline
Old 06-30-2019, 09:48 PM
RickyPersaud's Avatar
1998 honda odyssey cylinder head cover bolt torque spec
RickyPersaud is offline
Old 07-01-2019, 12:10 AM
MM Gruppe B
MAD_MIKE's Avatar
Same as most Hondas
Two posts up is your answer.
MAD_MIKE is offline
Old 10-25-2019, 08:11 AM
Ugo
Ugo's Avatar
Do NOT listen to the Honda spec. I read through just to see what it would be and tried it on mine, and snapped a bolt. Use the 2 finger method. Tighten down until the bolt touches the valve cover, in the out to in cross pattern. Then go back in the same pattern and only tighten down with 2 fingers until it becomes slightly difficult to turn and your DONE!
Ugo is offline
Old 10-22-2021, 02:10 PM
Freshh20's Avatar
Considering you never tighten from the outside in in engine heads, intake manifolds you name it. Because you will create a bow in the center and crack it or at the least not have a good seal. I would suggest sticking by the same practices for the valve cover. You loosen from the outside in and tighten from the inside out. Never tighten anything from the outside in. Even not car related same rules apply, trying to screw a sheet of plywood down flat to something and putting in screws from the outside edges and working your way in will push a bow/warp into the center of the board and crack it. You can even crack a head or intake manifold if you loosen from the inside out. Tightening isn't the only risk.
Freshh20 is offline
AndThenYouSay
01-18-2010 05:19 PM
my93hatch
02-16-2005 04:19 PM
Phoenix_ITR
06-17-2002 07:10 PM
capcon83
03-31-2002 03:38 PM
1fastGSR
10-01-2001 04:20 PM
Quick Reply: torque specs for valve cover bolts?
