Del Sol Valve adjustment
Old 05-04-2003, 05:16 PM
DMF
DMF's Avatar
Default Del Sol Valve adjustment
I need to adjust the valves on a 1995 Del Sol Si. However, I do not have a helms. What clearance are the intake and exhaust valves supposed to be set to?? Also, what is the order of the pistons at TDC as you turn the crank pulley? Thanks in advance.
Modified by DMF at 6:57 PM 5/4/2003
Old 05-04-2003, 06:28 PM
Pengo's Avatar
Default Re: Del Sol Valve adjustment (DMF)
order should be 1 3 4 2.
i dont remember the valve lash specs and i dont have my manual with me here rite now. good luck
Old 05-04-2003, 07:13 PM
nema741's Avatar
Default Re: Del Sol Valve adjustment (Pengo)
uhm... .07 on intake, .09 on exhaust... i'm doing that off memory but i'm almost positive thats what the manual recommends
thkohlb
08-23-2013 08:58 AM
DMF
05-05-2003 11:08 AM
Frcfedintegra
05-06-2002 03:07 PM
Jason
03-03-2002 09:21 AM
Quick Reply: Del Sol Valve adjustment
