** Passenger side Floor is ALWAYS WET after rain **
Old 04-22-2003, 03:31 PM
mz3bo's Avatar
Default ** Passenger side Floor is ALWAYS WET after rain **
I have this major problem, there is not rust no where on the car and the car had never been into an accident or somewhat... But, after it rained a lot, the passenger side floor is always soaked with water... I can't see from where it is coming from, anyone here ever experimented such situation ?
Thanks
Old 04-22-2003, 03:33 PM
IS3Fifty's Avatar
Default Re: ** Passenger side Floor is ALWAYS WET after rain ** (mz3bo)
leaky door seal...
Old 04-22-2003, 03:38 PM
tonyxcom's Avatar
have you recently had your windshield replaced? Or do you know if it has ever been replaced?
Old 04-22-2003, 04:43 PM
mz3bo's Avatar
Nah... none of those situations happened recently
Old 04-22-2003, 04:46 PM
Del
What car are we talking about here???
If it's a Sol it's definitely your front seals
Old 04-22-2003, 04:47 PM
mz3bo's Avatar
It's a 92 Civic HB DX
Sijray21's Avatar
does it only happen when you drive in the rain, i used to have that problem, ended up being a leak from the wheel well.
Old 04-22-2003, 04:48 PM
Risky Business
BauleyCivic's Avatar
Default Re: ** Passenger side Floor is ALWAYS WET after rain ** (Sijray21)
yaeh...have all ur seals checked...window seals, door seals, hood seals, and trunk seals...my friends coupe is leaking...we believe its a leaky trunk seal
Old 04-22-2003, 04:49 PM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sijray21 &raquo;</TD></TR><TR><TD CLASS="quote">does it only happen when you drive in the rain, i used to have that problem, ended up being a leak from the wheel well.</TD></TR></TABLE>
yeah and check that seal too
mz3bo's Avatar
Default Re: ** Passenger side Floor is ALWAYS WET after rain ** (BauleyCivic)
It only happens when the car is parked... especially if the right side of the car (passenger) is tilting lower than the driver side...
Old 04-22-2003, 05:29 PM
Zanpakuro's Avatar
Do you have a amp? Cause my car leaks also.
I had to cut the rubber grommet to run the wire to the battery
Old 04-22-2003, 06:51 PM
Slow CX's Avatar
Default Re: ** Passenger side Floor is ALWAYS WET after rain ** (TODAeg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TODAeg6 &raquo;</TD></TR><TR><TD CLASS="quote">leaky door seal...</TD></TR></TABLE>
I will go with that to. Mine does the same thing. It leaks like above the handle for the window where the door closes.
BLeSR
12-22-2010 12:58 PM
tehredls
05-05-2009 12:09 PM
92EGMINIME
04-08-2009 12:34 AM
N1ghtM0nkey
16
07-13-2006 11:55 PM
Quick Reply: ** Passenger side Floor is ALWAYS WET after rain **
