roof seal leak
roof seal leak
I had a leak on my passenger side roof at the section where top of the roof comes off at the front. Its about where the cornor of the window (the glass part that doesnt go down) meets the seal. Also i noticed when the door is closed i can sort of push it in a little more, like the door isnt completly closing, anyone help me?
Re: roof seal leak (tehredls)
hey had the same problem......i got a new seal and nothing happened...i ended up having to adjust my whole door up so it would create a tighter seal...this worked and my latch was sort of tight its fine now no leaks idk if that would help you or not
Re: roof seal leak (hondatuning1989)
yeah i just bought new seals for the front window and the passanger side roof and nothing happened.. how do you go about adjusting the doors? if it worked for you i want to give it a shot
Re: roof seal leak
Please, can you tell me how you fixed your leak problem? I am having the same problem now with my 97 Del Sol. How do you adjust the doors to make them more snug?
Re: roof seal leak
i'm having the same problem too, so far i've tried making the window go higher by adjusting it. Check out the helms pages http://www.knology.net/~jediklc/ then click interior and exterior parts and click on door 1, 2 and 3 it'll show you how to adjust the windows
